CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Alternator Problems?
Old Jun 9, 2015 | 06:29 PM
Mi55ile_AMG's Avatar
2003 Mercedes Benz CL55 AMG
Unhappy Alternator Problems?
Hey Guys!
I'm going to put this as straight forward as i can.
About 2 weeks ago while i was driving my 03 CL55, i noticed that the interior lights were flickering.
It isn't just the lights it is also every button that has a red light on it.
At first i thought it was a battery issue so i purchased a new battery but the same thing was happening.
Now it is at a point where my windows wont even go down nor the sunroof.
The scariest thing is when i drove at night, the headlights would just simply turn off.
So for the past 2 weeks it's been parked and i don't want to continue driving it until i figure out whats wrong with it.
Could it be that i may need a new alternator? If so, can it be rebuilt?
-Levon
Old Jun 9, 2015 | 07:13 PM
eaks's Avatar
2005 CL65
I would check all ground connections.. Most likely a ground is loose and causing issues..
Old Jun 10, 2015 | 04:59 PM
biker349's Avatar
cl600
check the voltage at the battery with the engine off, then on. voltage with engine off should be in the 12 volt range, engine on voltage should be in the 13-14 volt range.
Old Jun 10, 2015 | 09:40 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
If it is the alternator, the brushes are pretty easy to change out VS buying a new alt.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Jun 11, 2015 | 01:45 PM
We checked the voltage and it would bounce from 12-15 dramatically.
Old Jun 11, 2015 | 02:30 PM
biker349's Avatar
cl600
sounds like the alternator is the culprit. probably the voltage regulator in it.
