My w215 CL55 ABC Delete Thread - Yellow Speed Racing Coilover Conversion and Review
Regards
Home Depot part.
“The hydraulic lines needed to be capped (3/8" brass female threaded pipe flare caps) and zip tied to parts of the chassis.”
Hope that helps. Op.
We can supply you with 2.0" 2.25" 2.5" 2.625" 3" 3.5" And 50mm, 60mm 62mm, 65mm 70mm Plus many larger sizes too.
Do you offer 20kg springs for the Yellowspeed coilovers on the rear of a CL?
Rick
Sorry for not responding. Please review my write-up on the road conditions. Our cars are extremely heavy cars and my preference for a stiff suspension may not be your cup of tea. However, if you do utilize a less stiff set of springs it will be costly to try to move to a stiffer set. Consider also that springs may sag (mine haven't) and that I am on the top range of clicks to stiffness right now (Fronts at 30, Rears at 26 now). The only reason I do not go higher on the rears is that the road feedback becomes noticeable at 28 clicks from soft.
Look up as much information as you can regarding the spring rates and its impact to the ride quality and make your decision. I initially discussed with Yellow Speed in detail about the spring rates but that was after the installation.
Picked up my 06 CL55 AMG with YSRS-coil overs (springs: front 20k rear 14k), W220 (2003 S500) front sway bar, front lower control arms, power steering pump and reservoir. The mechanic set both front and rear on soft settings. The ride was too bouncy, so the settings were set f: 28 R: 25. This helped but still not quite enough (ride home from office tonight will be: front-30, rear-27. Without an alignment, road attitude was quirky, so went to Midas for alignment. They were able to set toe (castor came back with correct toe setting), but camber was -2 degrees and not adjustable. Mechanic ordered camber bolt kit for Mavis to install-align tomorrow. This should bring decent road manners. One thing that's nice...No ABC warnings then failure. Will report back tomorrow.
After a few adjustments, the car has settled down nicely and my confidence in the Yellow Speed suspension continues to grow. Unfortunately, I do not drive my car that much so the mileage updates will be slow. However, I will say one thing... I am no longer worried about the ABC.
Pointers for anyone attempting this...
1. If you set your car height too high - you will encounter bounciness.
2. If you set your car height too low - you will scrape.
3. Do not pre-load the springs.
The items above are subject to your wheel set-up. I am on 20" wheel setup.
4. My comfort height (just staying clear of rubbing in the wheel arches while tackling the jacked up roads in PA) is 27 inches in the rear and 26.75 inches in the front. You may need to go back for adjustments as the springs settle in your first 500 miles.
5. Do get a full alignment after a break-in period and before you judge or make any hasty decisions or changes. Negative camber will be your enemy on the fronts. Get this fixed.
6. My damper settings are now 32Fronts/27 Rears (from full soft).
7. For my wheel set-up do not set the rear dampers above 27 from full soft. If you do so the ride will become unpleasantly harsh.
8. If you are not a fan of a stiff ride I would say set your car to 28 Front / 25 Rear.
Sale Time: Anyone want a set of used Shocks from my CL55 AMG? Please PM me... we can work out the details on price there - they will be cheap with full disclosure...
Our cars are heavy and the fronts should be set higher than the rears.
BTW.. I also picked up a 2006 W211 E55 (18 inch standard wheels) a month ago and I also drove around with my neighbors 2005 W211 E55 (20 inch wheels). All the cars had a less than desirable drive due to the road conditions. Airmatic doesn't impress me either! The roads in my area are just plain crap!
so here’s my question
it seems we’ve discovered the w215 requires slanted top mounts
does this mean the W220 swaybar/w220 control arm setup will require the flat top mounts?? If anyone has any info please update because I really need new coilovers
edit- to clarify , I’m replacing my strutmasters setup on my 2002 cl500 chassis, but want to do front sway bars and W220’s control arms without manipulating my coilovers to reach the different mounting spot for the W220’s control arms since they are different
looks like i'll ask for some 14kg front and 12kg rear rates... and then add a front sway bar.. no rear sway bar
i remember reading that 20 front 20 back was way too stiff. i wish we had more info on kits between 14/10 and 20/20...
Here goes my completed 2003 CL55 AMG Widebody W215 with 20x12 R and 20x10 F ROHANA RFX5 Wheels on YellowSpeed Coilovers.
