CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
CL63 harsh downshifts
Old Oct 14, 2016 | 01:21 PM
kj217's Avatar
W211 E63
my 08 CL63 downshifts into 3rd gear noticeably harsh and rigid. it downshifts fine if i manually selected 3rd down from 4th. it is better in C mode but it is annoying in S mode.
is that normal?
thanks.
Old Oct 14, 2016 | 02:56 PM
BlackwidowGLE's Avatar
CLS350 | W211 E280(Retired)
When was the last time you changed your trans fluid, filter?
Old Oct 14, 2016 | 03:23 PM
kj217's Avatar
W211 E63
less than 3k miles ago.
Old Nov 14, 2016 | 06:23 AM
The_Swede's Avatar
CL 55 AMG, W215, 12/2003
Try resetting the control module
A harmless kind of try - resetting the gearbox control module:
1. Get in to the car and close the door
2. Turn on the ignition (step2)
3. Press down the gas pedal / accelerator and hold it for 15 sec. (activate the kickdown contact)
4. Keep holding the accelerator while turning the ignition off
5. Remove the key and release the pedal
6. Wait for approx. 2 min. - U R done
Why? the software controlling the gearbox is adapting to your drivings style, and if you have been aggressive, the module adapts and expect you to continue beeing aggressive :-)
See it here
Old Nov 14, 2016 | 12:31 PM
biker349's Avatar
cl600
good info. thanks
