CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
ambient light
Old 03-14-2017, 04:24 PM
v8mercedes's Avatar
CL 600 '04, Porsche GT3 RS '08, CLS 500 '05, SL 500 '92
ambient light
hello MBworld,
anyone have a trick or a idea to raise the ambient lightness in a 04 W215 V12 TT?
do you need DAS with developper mode or can change it in a modul (SAM??)
THX a lot
Old 03-19-2017, 02:40 AM
v8mercedes's Avatar
nobody any idea?
Old 03-20-2017, 05:55 PM
member
pmercury's Avatar
CL
I've seen that option in DAS
never tried to activate it as it says "not present"
but I could try
Old 03-20-2017, 06:20 PM
v8mercedes's Avatar
this will be great if you can try that for me. Thanks a lot for your help.
Old 03-20-2017, 10:56 PM
member
pmercury's Avatar
CL
I just did enter that option in the "developper" part of DAS but a line says "this should always be on "not present"
Old 03-21-2017, 04:36 PM
v8mercedes's Avatar
thank you very much....
did you try to change "not present" into "present"?
i have heard that it is possible on the w211 models to raise the lightness from 6% to 15%.
do you have some screenshots, please? it is easyer to find the modul to change the option.
again, thanks a lot for your help
Old 03-21-2017, 08:31 PM
member
pmercury's Avatar
CL
Nope, didn't try, don't want to try stuff like that and burn out something
but I looked for you in simulator mode but can't find it in this mode
so tomorrow i'll paste you where it is so you try
Old 03-23-2017, 04:50 PM
v8mercedes's Avatar
I can absolutly understand that.
after you told me the way to change it i will risk it. maybe i will burnout something but it is still worth a try.
again, thanks for the help, I appreciate that very much
Old 03-26-2017, 03:18 PM
Solo wing's Avatar
2020 E 300 Coupe and 2019 GLS 400
I think what this does (assuming it is possible) is it sets the level of brightness to the highest level. I noticed that on both my cars, when you enter or exit the car, the ambient lighting becomes bright for the first few moments and as soon as I close the door/switch ignition the lighting fades to a barley noticeable level.
Old 03-26-2017, 04:53 PM
v8mercedes's Avatar
i hope it is possible to raise the brightness on the highest level. my ambient light is next to nothing. there is sadly no difference if the door is open or not. i checked the LEDs and they are correct installed.
hope pmercury leaves the information with a screenshot where he found the option to change between "present/not present"
Old 03-27-2017, 01:52 PM
member
pmercury's Avatar
CL
here is your info
this is in developer mode, so enter development data
BR24 stands for MAYBACH 2003
stufe means level
Old 03-28-2017, 03:13 PM
v8mercedes's Avatar
thanks for this great information and the screenshots.
i tried to change it today. sadly there was no difference between the brightness as i raised the level from 1-5.
i will install some brighter LEDs in the door handle housing.
Quick Reply: ambient light
