Installed Lowering Links - Help...
Shopping...
So I just installed lowering links on my 05 CL 55. The rear goes way up and also when settled doesn’t go very low. The front doesn’t seem to move at all. It’s just sitting pretty low.
I am not sure if I should just re-adjust the rear to be lower or find a way to make the system re-learn the link lengths? The fear is that of the rear isn’t showing it’s real height because the system learned wrong somehow - also causing the front to not raise.
What are your thoughts?
