Urgent Need Help With My CL
I own a 2005 CL65 AMG, with a Eurocharged bench flash tune. Theres a very odd issue occuring at the moment. The car feels like it has no power, it used to have that feel where it would push you back into your seat, that no longer exists just feels as if the boost is not there. I had the drivers side Coils and plugs changed in 2018 and passengers side changed in 2015 both with less then 10k on them. Had the radiator changed aswell recently. Most frustrating concern is that the car just feels as if there’s no boost present although i can hear the turbos spooling up and they are pretty loud when flooring on 3rd gear, its almost like the turbos are trying to put out the boost but cant you can feel the boost in the first second or 2 on throttle and then it just quits, gas mileage is also very bad. At this point im not sure whats going on. Theres no CEL, or any other lights or codes present. Any insight would be gratefully appreciated.
It is the sensor attached to the metal bracket and sits elevated above the throttle body/ignition transformer. I have broken this during service and experience huge power loss and no check light.
Best of luck,
