CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
CL63 Fluid Leak
Old Sep 17, 2018 | 10:41 AM
snagster123's Avatar
CL63 AMG
CL63 Fluid Leak
Hi. This is my first post and my first Mercedes.
Got this car about 2 weeks ago from a Gov Auction and when I got it, it was 4 qts low on oil, 2 gal low on coolant, and the ABC fluid was empty and the ABC was not working at all. Got all fluids topped off and now the ABC is working but there is a bad leak. it appears to be the ABC fluid. It is not motor oil,or coolant... it is rather clear and looks just like the ABC fluid I just refilled.
Any ideas where typical leaks start, or where I should look?
Thanks,
Andy
Old Sep 18, 2018 | 11:30 PM
CL63 AMG
alright peps... found the leak... O-Ring on the black "ball-thing" on top of the pump. O'ring was shot.... Good to go now.
Old Jul 19, 2021 | 03:59 PM
ABChyraulic's Avatar
mercedes SL 500
hey does anyone know why this leaks ? ?? profusely ?? while the engine is running?
Old Jul 20, 2021 | 06:33 AM
Renntech6509's Avatar
2014 ML350
I assume you're talking about the pulsation dampener mounted directly on the pump. There's no o-ring for that. Maybe the dampener is just loose.
Old Jul 20, 2021 | 06:54 AM
mercedes SL 500
yes this
I have a gusher right there
Old Jul 20, 2021 | 10:56 AM
2014 ML350
Can you try getting a different angle? Kind of hard to see. But if it's the dampener, try torquing it.
