CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
CL65 w216 instrument cluster and steering wheel buttons unresponsive
Old Sep 18, 2018 | 01:15 AM
Gmadcl65's Avatar
Mercedes cl65
I accidentally left the front driver side fuse box open. I believe water may have gotten in. The tachometer and speedometer and water temp gauges all unresponsive. Most error lights are on. Seems like the dash is getting no signal. Steering wheel buttons unresponsive. Could it be the drivers side SAM? Please help!!
Old Sep 18, 2018 | 01:40 AM
ItalianJoe1's Avatar
2003 CL 600
Start with a scan with an SDS, don't guess at it. Yes, it could be the front SAM, but it could be anything on the network. Throwing parts at it will quickly get more expensive than having it properly diagnosed.
Old Sep 18, 2018 | 01:54 AM
Gmadcl65's Avatar
Mercedes cl65
Thank you. I appreciate the response. I have done a scan with the sds. No errors come up and cluster still unresponsive. Changed the CAN already.
Old Sep 18, 2018 | 02:46 PM
2003 CL 600
Changed the CAN? what does that mean?
Does the cluster respond to the SDS? Can you run the actuations?
Old Sep 18, 2018 | 03:57 PM
Gmadcl65's Avatar
Mercedes cl65
The Central Gateway Module. I have not tried that yet. I will try it. Do you know if I would need to have the front driver SAM programmed after replacement?
Old Sep 18, 2018 | 06:47 PM
1ForcedBenz's Avatar
Benz
Yes you definitely need to have it scn and programmed for your vin.
Old Sep 18, 2018 | 09:47 PM
Gmadcl65's Avatar
Mercedes cl65
Okay, thank you. I appreciate all the help ����
