CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Does the CL55 also have the notorious w215 speedometer issues?
Old Nov 23, 2018 | 07:18 PM
ctravis595's Avatar
2002 CL500 to CL55 conversion
i bought my car as a 2002 CL500, with the 2002 CL55 engine swap I would eventually like to upgrade the speedometer to one from a CL55. My car had the speedometer recall done in the 2000’s. Now it is starting to flicker and dim unexpectedly
From what I’ve researched this is a common issue, I see there are repair services on eBay and such. however im unsure if this was largely a CL500/cl600 issue, or if it also was common with the cl55 models as well. If the speedometer needs rebuilt I would hate to know once the speedometer is installed
Old Nov 26, 2018 | 12:43 PM
wes512's Avatar
2002 CL500
mine went out, but if u buy another one, i think the miles start over, i had mine rebuilt, but b4 i did , i brought an extra one just incase, i can give it to you for 100, i brought it for around 200
Old Nov 26, 2018 | 01:20 PM
ctravis595's Avatar
if it’s the cl55 speedo for AMG consider it sold
Old Nov 29, 2018 | 08:40 PM
pawraw's Avatar
CL 55 AMG
Speedo
I had mine repaired by a seller on ebay- they did a fantastic job and the turn around time was only a day.
I'm not sure if the link will go through. https://www.ebay.com/itm/Mercedes-W2...ndU:rk:16:pf:0
Seller name is mvkmimi1
