CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Soft door close repair/repair kit
Old Apr 2, 2019 | 02:43 PM
AMG_55_cruiser's Avatar
2004 CL55, 2003 SL55, 2017 S63 Cabrio and 2009 G55
I’ve seen couple threads on repairing the soft close actuator (#215-720-13-35) with mixed results/longevity. Has anyone used one of these repair kits?
https://rover.ebay.com/rover/0/0/0?m...2F391744492304
Half the price of new OEM replacement...deciding on the (3) options:
1) take apart of try to fix
-pro = lower cost/con = still time consuming and risk won’t fix
2) repair kit
-pro = half cost of oem replacement/con=same as repairing plus additional cost
3) oem replacement
-pro = will fix/con price (get what you pay for)
Any info on repair kit would be appreciated.
Thanks,
Mick
Old Apr 3, 2019 | 06:32 PM
superveloche's Avatar
2007 SL55 P030, 2005 CL55 AMG
I have a repair kit. didnt use it until now and i really dont know if to use it. i understood that the repair kit if very likely to brake again after a short period of time (maybe a few months).
Whats wierd in my car (have to mention ihave her only 3 weeks) is that neither both doors and trunk are not working. make me wonder if its not the kompressor faulty.
Old Apr 3, 2019 | 08:31 PM
sounds like I may just buy new oem replacement
I would recommend you search about the central vacuum pump. I read several that had details about none of the doors or trunk working.
Old Apr 3, 2019 | 08:49 PM
I am also considering buying a new oem part but i just understood that the door locking mechanism is different for cars with or without keyless go. Need to be investigated more!
About the central vaccum pump, wierd thing is that the massage and seat cussions works fine. I know that the central vaccum pump is also responsible for the seats cussions and massage. can it still be the central pump?
Old Apr 4, 2019 | 12:12 AM
About the central vaccum pump, wierd thing is that the massage and seat cushions works fine. I know that the central vacuum pump is also responsible for the seats cushions and massage. can it still be the central pump?
You are correct that that I believe the keyless go and non-keyless are difference. I may be mistaken that the vacuum pump for doors and trunk are same for the seats (that I am aware of)...again do some searching on subject. Regardless until you do testing of pump, fuses and relays.
Good luck
Old Apr 4, 2019 | 12:33 AM
ItalianJoe1's Avatar
2003 CL 600
One pump for everything, door locks, rear headrests, all of it. So if some of it works, the pump is still alive. Reset it and see what doesn't work or leaks. You most likely have multiple leaks if several branches are down.
Old Apr 6, 2019 | 05:56 PM
How should i do a pump reset? disconnect the batery? or there is another way?
