CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
SUSPENSION UPGRADE - TOTAL SYSTEM
Old Jan 22, 2020 | 03:49 PM
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
Old Feb 4, 2020 | 09:18 PM
Malendro's Avatar
2005 CL55
Do you have solutions for a w215 55k coilover conversion?
Old Feb 4, 2020 | 10:52 PM
K-Mac's Avatar
SPONSOR
Yes Front Camber and Caster adjuster kit provides precise single wrench adjustment. Up to 4 times adjustment range of the inaccurate (one offset position) fluted bolts.
Also same time replacing the 4 front highest wearing suspension bushings.
Bushes are Mono ball / 2 Axis design. Significantly improving brake and steering response #502516K $480 (set of 4).
REAR similar Camber (and extra Toe to compensate) adjuster kit. Replacing the lower arm inner bushes which retains important top of tire to outer fender clearance when wanting to reduce costly premature, inner edge tire wear. Bush extraction tool included #502226 K $480
REAR Popular Uprated bushing kit for the 6 multi link rear arms. Less twitch, flex, loss of traction.
Especially when applying power to lane change / overtake #502828 K $480
Delivery $40 one kit ($20 each extra)
