Selling a good used condition lowering module by Brabus it came off of my s 55 amg
He will fits s and cl class 2000 to 2006
if interested call or text to 510-541-9196
Is fixed but it does have 3 options to adjust the car The positions of the switch are as follows:
left position: 20millimetres lower
center position: 13millimetres lower
right position: standard height
- switch the ECU-switch to the left position,
- start the engine,
- adjust the car to its highest position using the switch in the dashboard panel,
- switch it to the lowest position, the car now will remain in the lowest possible height.
The fact that the red LED is blinking from time to time is totally correct,
this is what the module should do when everything is fine.
The red LED shows the can-data exchange betwenn the ECU`s is in progress
Is fixed and The positions of the switch are as follows:
- start the engine,
