Leaky abc reservoir?
Video:
And if that is the only oil seep, quick take a series of photos showing every potential leak location and share them. 99.9% of us have never seen a completely dry MBZ V-8 or V-12. MBZ continues to use a- RTV material in-place of conventional gaskets in most joints. GREAT IDEA, BUT!!!! because their CNC finishing machines do not leave a small 'gap'.between the 2,3,4 or 5 separate components meeting at a point, there is not enough room for any sealing material that will survive the continual thermal and stress loading caused differential expansion/shrinkage in the complex joint. Compounding this fundamental error in joint design, the aluminum alloys often have minor 'porosity' in the sealing surfaces and those are filled with oil during the machining processes and are not cleaned sufficiently to remove all the oil.. The RTV sealants WILL NOT ADHERE to oily surfaces. They will 'look good' but have very poor 'peel and un-stick' strength and will soon start to seep etc. etc. Remember there is no 'compression' in this joint to aid in sealing like there is in conventional gaskets. 'Sealing' a joint that will not allow oil to creep/seep through requires a good molecular BOND by the sealant to both surfaces to be sealed. Simply laying in there, fully cured with no compression force will not prevent oil or coolant from seeping out. These liquids are actually formulated with 'oiliness' additives,and 'wetting agents' to improve the lubricating performance in the moving surfaces.
