CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
ABC pressure sensor on 2005 CL55
Old Jun 24, 2021 | 10:17 PM
gearco's Avatar
Mercedes CL55
The pressure sensor on my car is showing bad on the diagnostic program; i located it under the car to the center right side and found the sensor in the picture. The Bosch number on the part is U 265005303. I found the part on Pelican Parts and it shows to be an ABS brake sensor. Spoke to a Mercedes specialist at Pelican and he swore the part number was an ABS brake part and not an ABC pressure sensor despite the fact that it was removed from the ABC pulsation accumulator block. The bigger O ring you see in the picture is supposed to be the "rebuild kit" for the ABC pressure sensor for my car. But as you can see it doesn't fit. I'm confused: is the part i removed the ABC pressure sensor? If it isn't, where is the ABC pressure sensor-I can't find it.
