CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
2005 CL55 AMG: Persistent Trunk Noise + Shifter Locked Issue
Old Apr 10, 2025 | 12:03 PM
ramboboujee's Avatar
CLK430
**Car Details:**
- 2005 CL55 AMG @ 155k miles
- Running on coilovers (previous owner converted from ABC)
- Horizon Blue color
**Parts Already Replaced:**
- Front suspension overhaul (removed driver side sag issue)
- Lower ball joints/control arms
- New front rotors
- Rear lateral tie rod thrust arms
- Trunk support struts
- Upper coilover bolts torqued to spec
**Issue #1: Persistent Trunk Noise**
I'm experiencing a loud noise coming from what sounds like the upper trunk area. The noise is particularly noticeable when going over bumps. Initially thought it might be the trunk struts, but replacing those didn't solve the problem. The noise seems to originate from the upper trunk area rather than from the actual suspension components.
I've already checked the basic suspects: trunk latch, loose items in the trunk, spare tire, etc. The noise persists and is quite loud - definitely not just a minor rattle. I've heard this could potentially be related to the rear subframe bushings or possibly remnants of the ABC system (though all ABC components have been removed and converted to coilovers).
**Issue #2: Shifter Locked in Park**
While working on the car, I jacked it up without setting the parking brake. Now my shifter is locked in Park and won't move. I'm guessing this is related to the shifter interlock system getting confused about the car's position. Has anyone dealt with this issue before? Any suggestions on resetting this without requiring a tow to a dealer?
Any insights would be greatly appreciated. This is a great car and I'm working through the issues one by one, but these two have me stumped.
Thanks in advance!
Old Apr 10, 2025 | 08:42 PM
JustTXn's Avatar
2005 CL55 AMG || 2005 CL65 AMG || 1989 560SEC
My cl55 makes that noise and it's the top of the rear tower struts for me. Jack the car up on one side just enough to get the rear tire off the ground, then move the rear tire up and down by wedging a 2x4 or crowbar between the tire and ground and lifting.
Listen to see if there is a noise from the shifter when you press the brake. If so, there is a plastic parking pall that snaps in half after a while and leaves you stuck in park. You can take the shifter knob off and smack the top of the shifter with a boot heel while your foot is on the brake, then see if you can shift out of park. If so, it's the parking pall.
Old Apr 10, 2025 | 08:48 PM
CLK430
Are you saying that noise is from the struts and not the subframe bushings? I thought it was the bushings honestly. The coilovers on the car are strutmasters which usually are reliable.
Also, the shifter issue happened last night, and then this morning, I was able to apply some pressure and move it to reverse, drove it round the block, then pulled into my driveway to park. after parking I could not shift anymore. they got stuck again. with that being said, does it sound like that plastic mechanism inside the shifter needs to be replaced? what baffles me is. the shifting was working before I put the car on jack stands
Old Apr 11, 2025 | 11:45 AM
CLK430
I want to say thanks for your feedback. I'm going to install a rubber washer and place it under the center nut. so basically what I'll do is I will unscrew the top nut in the rear behind the headrest on the passenger seat and it's a 19 mm nut and I will unscrew that and place the rubber washer then I will tighten it. but first I will jack up the car on each side one one at a time. so there's more pressure then I will place the washer and then I should be able to tighten after that and hopefully that noise will go away. as far as that, dead body in the trunk kind of noise LOL. wish me luck
Old Jun 23, 2025 | 09:54 AM
CLK430
Solved
That rear trunk noise was due to the coilovers failing from the previous owner.
Old Jun 23, 2025 | 02:13 PM
JustTXn's Avatar
Thanks for the update!
