CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
P0410 Code on 2005 CL55 AMG - Secondary Air Injection Issue
Old May 14, 2025 | 12:06 PM
ramboboujee's Avatar
CLK430
I recently replaced valve cover gaskets, spark plugs and coil packs on my 2005 CL55 AMG. Shortly after, I'm getting a P0410 code (Secondary Air Injection System Malfunction) when the car is idling.
The code initially appeared about a week and a half ago, but I cleared it thinking it might go away after the valve cover and intake gaskets work. It's now back and I'm trying to figure out if I caused this during my recent work or if the secondary air pump is actually failing.
Car has 155k miles, ABC suspension converted to coilovers, and overall runs strong despite this issue.
Has anyone else dealt with this? What was your fix? Should I first check the pump, relay, fuse, or check valves? Is it related to my recent spark plug/coil pack/gasket work?
Any advice greatly appreciated as I'd like to avoid unnecessary parts replacement.
Thanks!
Old May 16, 2025 | 01:17 AM
smgak's Avatar
C230K
How soon after your replacement work did this trouble code appear? You may have forgotten to connect an electrical connector, or maybe connected some vacuum hoses incorrectly.
Old May 16, 2025 | 10:57 AM
CLK430
exactly my thoughts as well but I took apart everything and I checked all the hoses and everything looks appropriately connected. I have ordered a new fuse in relay hoping that this is the issue. if it's not I'm going to have to replace the secondary air pump under the car which is not a big issue. I just didn't want to do that
Old Jun 23, 2025 | 09:52 AM
CLK430
Solved
Update, I was able to fix it by replacing the relay, secondary air pump, and secondary air valve. (The valve was clogged). No more codes!
