CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Sunroof not working? My fix and procedure.
Old Jul 22, 2025 | 01:07 AM
JustTXn's Avatar
2005 CL55 AMG || 2005 CL65 AMG || 1989 560SEC
So,
The sunroof on my CL65 was very intermittent, then quit functioning. Error codes referenced sensors in the sunroof motor (limit switch open circuit or short I believe).
Began troubleshooting, no clicks from the sunroof relays while attempting to operate via switch.
I disconnected the sunroof motor, and lo and behold, the relay clicked as it normally should when pressing sunroof buttons. Plug motor back in, nothing. Next attempt- pressed sunroof button to engage relay, then plugged in motor while holding sunroof switch. SUNROOF MOVES! A tiny bit anyways. Bought another motor off ebay (cheap). Same error, no change.
Next stop, grabbing a used overhead control unit (houses the relay, map light buttons, etc. PROBLEM SOLVED! 85% anyways. I can use the sunroof, but it will not function automatically even after learning procedure. whatever, might be a slightly different PCB. IDK, IDC. Good enough for me.
So, try an Ebay used overhead control unit if your sunroof exhibits the same symptoms as mine. $40 fix.
Old Jul 22, 2025 | 10:59 AM
ramboboujee's Avatar
CLK430
Nice! Definitely going to save this because I'm sure I'll run into this.
