window tinting
Does anyone here have any experience with this and can help shed some light?
Thanks.
The lines in the rear window are all defroster lines. The FM/AM antennas are located behind the black upper strip of the window under the headliner.
Make sure whatever you do that the tint shop lines the inner plastic window scrapers on each door panel with moleskin or you will start to get vertical scratches eventually from the hard plastic scrappers rubbing up against the tint.
Some shops cut the scrapers out but that leads to increased road noise and loose fitting windows. Lining them with moleskin which is like felt with an adhesive backing will cure these problems.
Also, make sure they are careful not to get water behind the door panels. The electronic modules located in the doors are an expensive part to replace.
Weather you go with metallic or non metallic tint is up to you. Metallic tint will last longer, has a deeper darkness to it and won't purple over time due to the UV saturation.
Do you mind if I ask you where you got your car tinted?
I am planning on getting my 202 re-tinted and want to know of good places to have it done.
Many thanks
Raoul
http://www.solarco.com/
818-891-6060
16149 Roscoe Blvd., North Hills, CA 91343-6226
818-891-6060
I will contact them.
