CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Transmission problem PLEASE HELP !!
Old May 17, 2009 | 10:10 PM
benzino118's Avatar
2009 E 63
Hi guys, check this out. I have a serious problem with my CL and I believe it's the transmission. Usually when I cross 230 km/h the car will suddenly loose power, however the rpm will build up while the speed of the car will only go up to 80km/h and it will regain power and speed after a couple minutes. Recently while I'm driving at a cruising speed of 100 km/h I will feel a "jerk" like if the gear changed very rough and the car's power will fail until it after a couple minutes it will come back to normal again.
PLEASE HELP ME GUYS !! I'm very lost....
Old May 20, 2009 | 12:23 PM
Patentmat's Avatar
Lots of views and no answers. I have not heard of too many transmission problems so you may be a trailblazer on this one. Keep us posted.
Old May 24, 2009 | 01:36 AM
2003 S600's Avatar
2003 s600
1. low on fluid or 2. too much torque for gear and tcu disengage tranny to protect it. Happens to me on occasion.
Old May 24, 2009 | 04:44 PM
benzino118's Avatar
2009 E 63
Ok thanks but if it is number 2, how do I go about fixing it. Thank you
Old May 25, 2009 | 06:36 PM
palicl55's Avatar
2008 CL63 AMG 2003 cl55 amg SOLD
i had a similar problem
i had a similar problem then i took it to the local dealer,the warranty replaced the IC pump which is the intercooler pump for the supercharger ,the super charger shuts off after it gets work and there is no cooler,cost around $800 including part and labor
Old May 25, 2009 | 07:35 PM
benzino118's Avatar
2009 E 63
Thank you very much for your help. So it could very well be the IC pump. Can you check that through the diagnostic testing?
Old May 25, 2009 | 07:56 PM
Oxygen's Avatar
W220 S65 AMG
Yes... you can hook up a scanner and display the IAT and see how hot it's getting.
Old May 28, 2009 | 06:52 PM
benzino118's Avatar
2009 E 63
Yes i am going to connect the diagnostic machine to the car and see how hot it will get. What do guys think about the Evosport cooling package?
