CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Remove side markers for W215
Old 04-08-2011, 09:35 AM
SLCL's Avatar
CL55, SL500, E350
Does anyone know how to remove/replace the side markers (blinkers) for the W215? Thanks in advance.
Old 04-08-2011, 11:07 AM
sunpointair's Avatar
2003 CL55
I just replaced mine with the clear markers. Its not to diffucult. I did mine in the garage. If you jack up on side at a time you can get under the front and you will see a removable panel in front of each wheel. Just twist the 2 tabs and remove it. The drivers side is actually a little more difficult to reach the side light. On the rear portion of the side light is flat, U shaped portion that you squeeze and push the marker out. It will tilt out. From there, just twist the bulb portion out. The front of the side marker has a couple of hook shape pins that will slide out. I actually couldn't get my large hand up in on the drivers side and had to use a long screwdriver. If you start with the passenger side you can get in there easier and really see what I am talking about ! Hope tis helps !
Old 04-08-2011, 11:09 AM
SLCL's Avatar
CL55, SL500, E350
Thanks for the tips . It clears up lots of questions. I will try it as soon as it warms up.
Old 04-08-2011, 12:11 PM
danlnyc's Avatar
04 CL55 (sold), 2012 CLS550 (sold), 2014 S550 (sold), 2015 ES300H (DAILY)
I just got a screwdriver, a towel, and popped it out with from the left side. Twist to remove the the marker from the bulb.
Old 04-08-2011, 10:59 PM
2003 CL55
That's interesting ! I started to do that and was afraid that i would either screw up the paint or break the side light ! My way is definitely more work, but, maybe safer ?
Old 04-09-2011, 02:15 PM
danlnyc's Avatar
thats why I grabbed a thin towel to make sure I dont stratch my paint it's very easy, it pops right out.
you can also turn your wheel completely to the left or right and do the same method as you said without having to jack it up
Old 04-10-2011, 03:20 PM
2003 CL55
I don't see how turning the wheel helps you with the access panel underneath ? I didn't see a panel in the wheelwell ?
Old 04-11-2011, 11:53 AM
danlnyc's Avatar
when I was installing my LED side markers and HID fogs that's how I installed them. Turned wheel all the way to the right to access left sidemarker. Then I pulled out a couple plugs, and used a screwdriver/towel to pull the panel out. I was able to reach both the LED sidemarkers and fogs that way.
Old 04-25-2011, 08:19 AM
SLCL's Avatar
CL55, SL500, E350
I used the "screwdriver method". Replaced both with clear ones in less than 5 minutes. Looks "clean". Thanks again.
Old 04-25-2011, 01:02 PM
2003 CL55
Ha ! Guess I learned something here ! Are the yellow ones still useable ? I figured that would break off the clip !
Old 04-25-2011, 02:05 PM
SLCL's Avatar
CL55, SL500, E350
The yellow ones are still intact. Since I had the clear ones in hand, I know exactly where the tabs/clips are. If you are just randomly pry without knowing, you could break the tabs.
Old 04-25-2011, 04:18 PM
danlnyc's Avatar
+1
Old 04-25-2011, 05:53 PM
Oxygen's Avatar
W220 S65 AMG
I just did mine last night... popped them out with a plastic knife, sanded, painted silver, dry and back in they go!
Old 04-27-2011, 09:00 AM
saintz's Avatar
GL450
A plastic spatula or other similar tool will pry them out easily.
Old 04-27-2011, 11:06 AM
SLCL's Avatar
CL55, SL500, E350
A picture of the clear lense. I also changed the city bulbs to LED.
Attached Thumbnails Remove side markers for W215-dscn0327.jpg   Remove side markers for W215-dscn0328.jpg
Old 04-27-2011, 06:16 PM
Oxygen's Avatar
W220 S65 AMG
Going... going.... GONE!
Old 01-16-2012, 01:18 PM
Hakop's Avatar
2005 CL55
Which side do u put the screwdriver in from the thinneer sharper part or the rounder part
Old 01-16-2012, 02:08 PM
danlnyc's Avatar
if you're looking at the sidemarker, it's on the left side. So I guess near the rounder part?
Old 01-16-2012, 03:22 PM
Hakop's Avatar
2005 CL55
The door side towards the door
Old 01-16-2012, 05:32 PM
danlnyc's Avatar
I hope this picture helps. Do you see where my hand is? Thats the side you will be popping it out from.
Old 01-16-2012, 05:50 PM
C280 Sport's Avatar
Location: Saratoga Springs, New York & Sarasota, Florida.
MB’s
Exactly! Just how I have done it before too.
Old 01-16-2012, 06:39 PM
Hakop's Avatar
2005 CL55
Tanx where can I get the clear corner for a decent price?
Old 01-16-2012, 06:42 PM
danlnyc's Avatar
I ordered mine from ebay for (I think) around 40 to 50 bucks? Sorry I don't remember....just look up CL55 side marker and it should pop up
Old 01-22-2012, 03:41 AM
Hakop's Avatar
2005 CL55
Tanx I put dem on
Quick Reply: Remove side markers for W215
