CL65 AMG Aux Inputs
CL65 AMG Aux Inputs
Hi All
Apologies if this question has been asked before I could not find anything on searches.
I use a Samsung S2 phone with a 64GB SD card in it that has all my Spotify playlists on it. I normally just plug this into an Aux port and off we go. I can see on the audio system there are 2 x Aux listed but I can not find a port anywhere. When I select either of them the screen scrolls down almost like a TV out of tune.
So Finally to the question. Can I connect a external device into the AUX on a stock system. If not is there maybe a way to achieve this?
Thanks in advance for you time and input.
PLATINUM SPONSOR
My glovebox has an aux port inside from factory, my wife plugs and plays her I phone in it.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
While I am on the Audio subject.
Is there anything special I have to do to play MP3's? I copied a bunch on a cd just to test and loaded it in the front, press MP3 CD and it just stays at loading. I am able to watch DVD's and play a music cd in the car.
Popping the disk in a PC works fine.
Hi All
Just for completeness I will update this thread. Thank you for the advice etc.
I had the mcar (http://mcar.us/) unit installed and it works a treat. USB port for IPod or memory stick. I have a IPod plugged in but I just use the Bluetooth audio streaming and play Spotify from my phone.
All the phone functions work great on the wheel and it makes your address book available in a few sec. As for the MP3 play back I believe this has been resolved with the comand firmware update as well. Although I have no need for it now with this bad boy installed.
Regards
Regards
2001 SL500, 2005 E55 AMG
Hi All
Regards
Regards
Thanks!
I didn't personally install it I had it fitted and it just hooked into the cars phone system including the mic so not sure if it comes with one.
All the artist/song info is displayed on the comand. The only thing displayed on the Spedo is "Track 1" etc. I am not a smoker so my smart phone neatly fits in the ashtray. I just scroll and select the songs on it and it displays album covers and all the info.
Regards
There is a special method on making DVDs that will hold your MP3's..
I tried it once like a couple years back and made one good DVD with a bunch of songs.. it works.. but to burn it, it's a special dvd burn mode. It's on the forum somewhere.. Don't forget, your DVD player is on the console and doesn't use the the CD Tray in the back.. only one DVD plays mp3s..
But meanwhile, I'm trying this out since I like to stream from my phone in different cars with bluetooth or not..http://thewirecutter.com/reviews/bes...ry-car-stereo/
or
http://www.amazon.com/gp/product/B00...29&camp=211189
