CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
My ABC Part Out Thread!
Old May 2, 2014 | 11:38 PM
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
Need an ABC part? Let me know! I have anything you'd need, and can get you what you need if it's not currently out of the car. Everything including:
(UPDATED)
- OES front valve block (approx 40,000 miles on this -- UPDATED!!)
- OES front and rear AMG-spec struts
- all corner height sensors and bracketry
- front and rear lower control arms
Everything was functioning perfectly prior to removal. There was nothing wrong with my ABC system, and there was absolutely NO dropping of any corner, even after sitting for well over a week.
Old May 8, 2014 | 11:17 AM
OCKlasse's Avatar
MBworld Guru
Bump. I will post pictures and prices next week. PM me now for quotes, though before the good stuff gets snatched up
Old May 8, 2014 | 01:19 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
I may be interested in a few parts , after you post pictures.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old May 16, 2014 | 05:43 PM
OCKlasse's Avatar
MBworld Guru
Old May 21, 2014 | 10:23 AM
kamilclk430's Avatar
W215 V12TT Build by Speedriven, W221 S550 4Matic
Have not seen you around on the forum lately all ok? How is the car?
Old May 24, 2014 | 05:07 PM
OCKlasse's Avatar
MBworld Guru
Hey! All good. Car is great! Work has kept me very busy
Old May 24, 2014 | 05:10 PM
OCKlasse's Avatar
MBworld Guru
Below are the factory ABC struts. All were working perfectly prior to removal with NO LEAKING. $200 each:
Factory lower rear control arms $100 for the pair:
Miscellaneous items (front lower control arms, height sensors, brackets, etc.) Let me know what you need:
Old May 25, 2014 | 02:40 AM
tusabes's Avatar
Mercedes
I know accumulators are a cheap item to buy new and probably shouldn't reuse old ones but how much for yours ?
Old May 25, 2014 | 12:37 PM
OCKlasse's Avatar
MBworld Guru
Which accumulators? All of them?
Old May 26, 2014 | 12:02 PM
1995E320Cab's Avatar
2003 CL600 2005 745Li
I have a case of ABC system fluid that I will sell for a good deal if anyone needs it.
Old May 26, 2014 | 08:22 PM
OCKlasse's Avatar
MBworld Guru
Does anyone need some accelerometers? $30 each or $50 for the pair.
Old Jun 12, 2014 | 12:07 AM
OCKlasse's Avatar
MBworld Guru
ABC pump is sold. I have interest in the rear valve block and pulsation damper.
Old Jun 12, 2014 | 02:45 PM
PLATINUM SPONSOR
2003 CL55
You have any motor mounts?
__________________
www.ultimatepd.com
Old Jun 12, 2014 | 03:21 PM
AndreNY's Avatar
couple of Benzos
what do those accelerometers sensors do?
Old Jun 12, 2014 | 06:07 PM
OCKlasse's Avatar
MBworld Guru
Sorry sir, those are still in the vehicle.
Old Jun 12, 2014 | 06:10 PM
OCKlasse's Avatar
MBworld Guru
Those are what determine pitch and roll. They tell the valve blocks which valve(s) to open to compensate for the pitch/roll being sensed. Basically without those ABC would be pointless.
Old Jun 12, 2014 | 06:15 PM
OCKlasse's Avatar
MBworld Guru
Rear valve block as well as the pulsation damper have been claimed.
Old Dec 26, 2014 | 12:42 AM
OCKlasse's Avatar
MBworld Guru
bump
Old Dec 27, 2014 | 12:02 AM
fireman685's Avatar
2005 CL55
Originally Posted by OCKlasse
bump
In case I decide to hold off on my strutmasters w220 conversion, what about the hydraulic lines? I have some weeping.
Old Dec 27, 2014 | 12:49 AM
OCKlasse's Avatar
MBworld Guru
Didn't keep them, unfortunately. I'd recommend buying brand new for that.
Old Dec 28, 2014 | 07:34 AM
principledchiro's Avatar
2006 CL55 AMG
OCKlasse, will you part with the small towing hook cover on passenger rear side of rear bumper? I need it.
Old Dec 28, 2014 | 07:57 PM
OCKlasse's Avatar
MBworld Guru
Sorry, I'm only selling ABC components.
