CLA 35, CLA 45 AMG (C117, C118) 2013 to Present, Two generations
Increasing the Power-Band! Mishimoto's CLA45 AMG Intake!
Old Jul 14, 2015 | 03:22 PM
Mishimoto's Avatar
Former Vendor of MBWorld
300D
Hey guys,
As some of you are aware, we recently completed the development of our intake system designed specifically for the CLA45 AMG. Our engineering team put a ton of work into extracting some extra power from the AMG, and we are very pleased with the results. A few of the key components of our kit are discussed below!
Silicone Inlet Hose Design
Our team designed a silicone inlet hose to replace the factory-equipped rubber piece. Not only is our unit more durable, but it also provides a huge improvement in airflow and eliminates restrictions and turbulence seen in the factory piece. Below is a look at our initial prototype and the stock unit.
Stock inlet tube (left) and Mishimoto inlet tube prototype (right)
The stock tube essentially bumps from the filter size directly to the small OD of the compressor inlet. This creates a wall at the end of the tube which may result in some airflow turbulence. To smoothen airflow in this area, our inlet tube is designed to provide a fluid transition from the filter to the compressor inlet, reducing the chance of restrictions or turbulence within this portion of the intake.
The computational fluid dynamics (CFD) software we use displays the velocity of a fluid (air, in this instance) passing through a component modeled in 3D. We modeled both the stock inlet tube and our counterpart to provide a nice visual representation of what we were able to achieve with our design. Check out the comparison below!
Inlet tube CFD analysis
For an intake system, you want to see the highest velocity possible. By eliminating the step in this tube and by providing a smooth inner surface, we were able to improve airflow substantially over the stock inlet tube.
The final inlet hose is shown below.
Mishimoto silicone inlet tube
Aluminum Airbox Design
To cope with engine bay heat, we’ve designed an aluminum airbox which encloses the filter and is fed air using the factory duct. Additionally, we have a port to accommodate the factory ECU heat sink.
Mishimoto prototype airbox
Rubber weatherstripping lines the edges of this unit to prevent any vibrations during operation.
Mishimoto intake system installed
Air Filter & Venturi
We are utilizing our Mishimoto oiled air filter with internal venture to provide optimal air filter surface area as well as optimal flow through the intake.
This unit sounds great on the AMG and provides fantastic flow.
Dyno Testing
We did not stop at design work, this intake also endured extensive testing to provide data for our power gains and to ensure this intake provided safe operation during all driving conditions.
Mercedes cold-air intake testing data
As you can see on the stock plot, the car builds power nicely through a majority of the power band but seems to fall flat at higher rpm, right around 5600 rpm. With our intake system installed, we were able to continue to build power all the way to 6200 rpm. Our intake allows for greater top-end power without sacrificing any power on the low end, which is great.
Within this upper range we are seeing maximum gains of over 20 whp and peak gains of 17 whp. These are great numbers, especially for a vehicle already making nearly 350 horsepower at the wheels.
Full testing details can be found at the blog link below!
Full Product Development Details
For a look at the full development, check out our engineering blog linked below.
http://engineering.mishimoto.com/?cat=262
Discounted Pre-sale Information
We are also running a discounted pre-sale for those interested in picking up our intake system. Orders will be accepted until 8/17, which is also the date we intend to ship out our first batch of intake kits.
Price: $374.95
Ship Date: 8/17
Full details regarding the sale can be found at the link below.
Mercedes CLA45 AMG Intake Pre-Sale Link
Feel free to follow-up with any questions/comments!
-John
Old Aug 11, 2015 | 09:59 AM
Mishimoto's Avatar
300D
Check out a few images of our final kit!
Just a reminder that our discounted pre-sale expires next week!
Let me know if I can answer any questions about our intake system.
-John
Old Aug 11, 2015 | 11:16 PM
tls1212's Avatar
A45 AMG Edition 1
can I just buy the silicone inlet without the aluminium box n filter ?
Old Aug 12, 2015 | 04:42 AM
MegaAerox's Avatar
A45 AMG
2x
Old Aug 12, 2015 | 03:19 PM
shaunee's Avatar
A45 AMG
Mmmmm... liking that silicon inlet pipework.
Can you ship these to the UK, if so what would be the cost please?
Old Aug 12, 2015 | 05:19 PM
Mishimoto's Avatar
300D
Originally Posted by MegaAerox
2x
Thanks for the interest guys! This component will only be available within our intake kit. We do not intend to offer the silicone inlet tube as an independent product.
Thanks Shaunee! We do offer international shipping, a quote can be obtained after adding our kit to your cart after following our pre-sale link. In addition, we will likely be sending several kits to our UK warehouse once these are released. If you don't mind waiting until these are released, purchasing from one of our UK distributors may be a better option in terms of expense.
-John
Old Aug 12, 2015 | 05:30 PM
shaunee's Avatar
A45 AMG
-John
Hi John,
Unfortunately your link takes me straight to the .co.uk homepage.
When will they be available in the UK?
Old Aug 12, 2015 | 05:48 PM
shaunee's Avatar
A45 AMG
Find a way of getting through to your .com site, but your shipping only lets me choose between the US or Canada.
Old Aug 13, 2015 | 03:06 PM
Mishimoto's Avatar
300D
Hi John,
Sorry about that! We should have a few units in our UK warehouse by October. If that isn't going to work for you, shoot me a PM with your shipping address and I will get a quote for you!
-John
Old Aug 13, 2015 | 03:11 PM
shaunee's Avatar
A45 AMG
Thanks John.
Old Aug 20, 2015 | 02:48 PM
Mishimoto's Avatar
300D
Thanks John.
PM sent with quote! Thank you!
-John
Old Aug 24, 2015 | 10:18 AM
Mishimoto's Avatar
300D
Thanks for all of the orders guys! Our kits have officially shipped, all pre-sale customers should have tracking information.
This kit is officially released, check out the final details below!
Mercedes-Benz CLA45 AMG Performance Air Intake, 2014+
Product Specs
  • Direct fit for 2014+ Mercedes CLA45 AMG
  • Dyno-proven maximum gains of up to 20 whp and 17 wtq on the stock tune
  • Mishimoto High-Flow Oiled Air Filter placed to receive maximum airflow from the front of the vehicle
  • 4" high-flow filter operates at up to 2,000 CFM, and eliminates the restrictive 3" inlet in the stock air intake system
  • Powder-coated black airbox keeps unwanted hot air from entering the air filter
  • Airbox made from Aluminum, for extra weight savings, and added corrosion protection in harsh climates
  • Silicone turbo inlet hose features CNC-machined ports and added reinforcement rings for durability under load
  • Highly aggressive intake tone under acceleration
  • Fits with the stock inlet duct in the front of the bumper
  • Installs in one hour with no need to remove the front bumper or splash guard
  • Designed in Delaware, USA and filter made in USA
  • Mishimoto Lifetime Warranty
Tech Specs
Features & Benefits
Installation
Product R&D
Images
Feel free to follow-up with any questions!
Thanks!
-John
