CLA 35, CLA 45 AMG (C117, C118) 2013 to Present, Two generations
rebellion blow off valve instructions?
Old Dec 24, 2015 | 04:21 PM
iamracerX's Avatar
cla45
anyone have good visual instructions on how to replace the blow off valve? i got one from REBELLION but what they sent me were very poor illustrated instructions. Thanks John
Old Dec 24, 2015 | 11:07 PM
P3T3's Avatar
Should be pretty similar
http://weistec.com/media/productfile...1/m133_asv.pdf
Old Dec 26, 2015 | 09:20 AM
iamracerX's Avatar
cla45
thanks!
Old Jul 11, 2023 | 01:21 AM
GLKwanter's Avatar
Rental
Shame these two seem to have disappeared from the forum. Would've liked to know if they ever got this fixed. I got the same exact result from changing both tensioners, leaving the check valves there in, and I swapped bank 2 intake adjuster sprockets. All this improved the idle at startup, which now sounds up to speed, but the rattle still persists till tensioners are lubed up.
I took video of all my cam adjuster sprockets to see if like all the videos on YouTube I could see them jump. The only one that seemed bad at all was the intake bank 2 (driver side) as it made a small click, like I saw in a one-hour total cam adjuster swap fix video, that I wasn't able to reproduce without the cams slipping, and I had to pull the valve cover. All the others seem okay, but still the rattle at startup.
Anyone ever thought of modifying a set of tensioners? Somehow, bolstering the springs to need less oil pressure? I read leaky tensioners can starve the cams of oil. Would love to get this all gone.
Old Apr 23, 2025 | 10:48 AM
bikir's Avatar
MB GL450 2015
Hello, may I ask how did you end up fixing the issue? thanks
