CLA 35, CLA 45 AMG (C117, C118) 2013 to Present, Two generations
blow off valve making car feel slower?
Old Dec 26, 2015 | 02:50 PM
iamracerX's Avatar
cla45
just installed the Forge BOV and for some reason the car feels a bit slower. probably just in my head but does anyone else agree? i can at least tell that the BRAPPPP sound has weakened upon gear change. anyway, just wondering what others have experienced. John
Old Dec 27, 2015 | 02:39 PM
J_Maher_AMG's Avatar
2011 WRX
Well you installed a part on the car that is not accounted for by the ECU, was not part of the original mechanical design, and had not been tested or proven to provide any tangible benefits other than a ricer "whoosh" sound...
Very few cars under 1000hp actually Require a vent to atmosphere blow off valve. This is also not AMG's first turbo engine, if it required a blow off valve, it would have been there from the factory.
Edit: You're losing power on shifts because you are letting pressure out... BLOW OFF VALVE, it does exactly as it states. The car is not designed to vent to atmosphere as stock, and it's why you're loosing power on shifts.
Old Dec 27, 2015 | 11:59 PM
peejalino's Avatar
Veteran: Air Force
AMG GT63S
This is interesting. I didn't notice it on my end, feels good to me. Maybe because I dont really push it often like others on here. I have the power there when I need it. Aesthetics wise it's still a car that still sticks out.
To each his own on perception of a "ricer" look.
Old Dec 28, 2015 | 12:15 AM
R0ME0's Avatar
'15 CLA45
You sure you installed it right? Shouldn't be a loss of power unless you have a
Boost leak or installed it improperly.
Old Dec 28, 2015 | 02:48 AM
peejalino's Avatar
Veteran: Air Force
AMG GT63S
Orr that too. Since I believe he mentioned the sound level getting softer?
Old Dec 28, 2015 | 04:32 AM
R0ME0's Avatar
'15 CLA45
Yea I'm betting 9/10 you got s boost leak. Check your hose connections.
Old Dec 28, 2015 | 04:02 PM
iamracerX's Avatar
cla45
the valve screwed together to hold the inside spring and i didnt want to over tighten it. is this perhaps where i may have boost leak? every where else i assured to be installed perfectly correct. thanks john
Old Dec 29, 2015 | 07:20 PM
iamracerX's Avatar
cla45
i tightened the BOV. seems right now.
Old Jan 5, 2016 | 06:55 PM
Alex.currie44's Avatar
2009 SLK55 AMG. & 2022 GLA250 4Matic
BOV
Just curious but why did you change it?
Old Jan 6, 2016 | 04:22 PM
iamracerX's Avatar
cla45
well to be honest, only because of the blow off sound. i know others may think its annoying but i enjoy it. as far as the exhaust note, nothing has changed and on sport mode, the BRAPPP sound is actually the same. i have read that the valve may be needed in the future with developing mods. John
