CLA 35, CLA 45 AMG (C117, C118) 2013 to Present, Two generations
CLA45 Spacers? H&R Springs? Sizes? Pics?
Old Mar 5, 2021 | 11:09 AM
dunsamg's Avatar
2020 CLA45 AMG
Hi, I am looking to purchase spacers and H&R lowering springs for my car. I can't find any info or pics on this because our cars are so new. Especially here in the US. If you've already done this, please share some pics and spacer sizes.
Thank you!
Old May 6, 2021 | 10:04 AM
(ZO)'s Avatar
08 AMG C63
Hi
Recently have installed H&R lower spring Part Number: 28657-2, a bit too lower for my taste, but that the only one available, unless you go for the KW coil over which is height adjustable but need to disable the automatic damper control which I don’t want.
Also I have try different width wheel spacer 20mm, 15mm, 12.5mm, 10mm, 8mm ,5mm.
Without lower spring it can run 20mm front and rear but is little bit too much, so without lower spring 15mm rear 12.5mm front is just right.
With lower spring I have try many combinations.
For the rear I have try 20mm will not work, 15mm is a bit tight, 12.5mm is just right without rubbing.
For the front I have try 20mm, 12.5mm both rub, brought a 8mm no centre hub lip can not install properly because it flush with the car centre hub lip, try a 5mm not thick enough, finally found a 10mm spacer with centre hub lip, but to install the 10mm spacer you need to remove the centre hub cap in order to install the 10mm spacer.
So with lower spring 10mm front 12.5mm rear.
Old May 6, 2021 | 10:16 AM
(ZO)'s Avatar
08 AMG C63
Old May 6, 2021 | 10:29 AM
dunsamg's Avatar
2020 CLA45 AMG
Originally Posted by (ZO)
it looks perfect in my opinion. Ill be lowering soon too.
but i do have 12mm spacers all around.
Old May 6, 2021 | 11:09 AM
(ZO)'s Avatar
08 AMG C63
It looks ok but scraping a bit when I go through speed hump, the rubber strip underneath the car in front is already ripe I cut the whole strip off.
Old May 6, 2021 | 11:32 AM
dunsamg's Avatar
2020 CLA45 AMG
Thanks! Hmm I may have to go the 10mm route. Unfortunately, I already ordered the 12mm spacers from H&R.
Old May 6, 2021 | 10:17 PM
(ZO)'s Avatar
08 AMG C63
sorry I mean the height is a bit low with the H&R spring
Old May 19, 2021 | 05:49 PM
Darth CLA's Avatar
2020 cla 45
So the tires rub at all with 12mm spacers all around without lowering? I like the wider stance look, but don't want to worry about any rubbing.
If you have pics that would be awesome too!
Old Jul 26, 2021 | 04:28 PM
dunsamg's Avatar
2020 CLA45 AMG
Do you have a link of the spacers you bought? I'll be putting 12mm rear and 10mm fronts as well.
Thanks!
Old Dec 12, 2021 | 06:34 AM
yuyu6's Avatar
CLA45s C118
Hi
Hey ZO, thanks for all the info provided here. I'm actually looking for wheel spacer for my CLA45s. So without lower spring, will there be any rubbing for 15mm rear and 12.5mm front? Will you recommend a 12mm front and rear? And do you have pictures of your car before lower spring with the wheel spacer installed?
Old Dec 12, 2021 | 07:31 AM
yuyu6's Avatar
CLA45s C118
Please post some pictures when you done install the 12mm spacers all around, would like to see the outcome. @dunsamg
Old Dec 21, 2021 | 08:01 AM
ModalWorks's Avatar
SPONSOR
W205 C63
We have 12.5 and 15 spacer in stock:
https://modalwork.com/products/hub-centric-66-5-wheel-spacers-5-x-112-15mm
Old Apr 8, 2022 | 06:38 PM
Chemical7's Avatar
2014 C63 AMG Edition 507, 2008 E63 AMG, 2016 C300 Daily
Hi
ZO, where did you get the 507 stripes? I like them on your car!
Old Apr 12, 2022 | 10:46 PM
MayhemAMG's Avatar
2022 CLA 45
Please tell me where you got the 10mm spacers I can’t find them anywhere. I will forever be in your debt.
Old Apr 21, 2022 | 02:40 PM
SolidC63S's Avatar
2019 C63S Cabriolet
WOW amazing car, I got an A35 AMG 2021 with everything loaded and reminded me of this. SO I heard they are not making the A35's sedans anymore....
