A special MB tool is needed to change belt.
PLATINUM SPONSOR
As part of mercedes methodology to keep your hands off your own car, you will now need a special triple square tool from MB to change your serpetine belt. Unless you plan to let the dealer charge you for this easy task
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
PLATINUM SPONSOR
__________________
www.ultimatepd.com
www.ultimatepd.com
