CLA Coupe (C117) 2014-present
P052E on CLA250
Old Sep 2, 2021 | 11:12 AM
Texas CLA's Avatar
CLA 250
So I tried the cleaning method through the vent line and it wouldn't drain. My plan now is to cut the feed line to the PCV and clean it from that end. I'll use a metal tube coupler with hose clamps to reconnect. If that doesn't work I was thinking about replacing just the valve using a PCV from a C300. The part is far cheaper than the one for the CLA 250 (it's just the valve and connecting tubing) and from everything I've seen, they look exactly the same. I'll update in the next week on how it panned out.
Old Jan 21, 2022 | 09:39 PM
PROmatic's Avatar
W463a,W222,G06,F06, MazDAtree
Any updates?
Old Jun 15, 2022 | 04:44 PM
Msb2022's Avatar
Cla 250 2014
Originally Posted by Mark Medynski
I just finished getting the valve unstuck...It took about 30mins...mostly because I had to do it it blind as the "vent valve # 3" is not the back of the intake manifold...All you have to do is to disconnect the rubber hose "purge line #4" and spray brake clean and let that dry...then fill the tube with WD40...When the level in the hose drops....you know the valve is unstuck....Pop the hose back on to the intake manifold and Bob's your Uncle!...Clear the code with your scanner and have a Beer...Job well done....Cheers
Nice trick. I have similar issue with same code but my messge says something like "the valve for positive crack case ventilation has a mulfunction. The actuator is blocked". What could this mean? Or which is the actuator that it is talking about. Any help would be great
Old Jun 27, 2022 | 02:51 PM
somoss0117's Avatar
c240
Update on GLC-300.
Any update on your fix for glc?
Originally Posted by sn202020
I tell you it goes to the engine oil pan thru the oil separator,s bottom return hole.
Oil is more than 6 liters in the engine. So adding 100 ~300 ml liquid is not too bad. I guess 5w40 becomes like 5w35 or 5w30.
it did not fix my p052e code completely. but less frequently code comes back.
Even though I tried 3 times.
Old Aug 24, 2022 | 10:15 AM
FawazSha's Avatar
2014 Mercedes Benz CLA250 4Matic
Can you post the link of Car Wizard's video please?
Old Aug 24, 2022 | 10:17 AM
FawazSha's Avatar
Yes...I also saw the Wizard's post...In his case he has to offer a more definite repair to his paying customers...the first time I cleaned the valve it did re-code after about a week...but it was not fully stuck as I was able to clear the code....as apposed to the first time it got stuck I could not clear it...So I popped off the hose that is connected to the intake...filled it with WD40...reconnected it to the intake...and let it soak over night...When my girlfriend went out in the morning to go shopping...I followed her out to clear the code....but when she started the car...the code was gone....I knew then that I was on the right track to fully cleaning it...
Old Aug 24, 2022 | 11:36 AM
  #32
somoss0117's Avatar
c240
Fixed
I found a fix on another forum and it worked. Here is my post: https://mbworld.org/forums/glc-class...-code-fix.html
good luck
Old Jul 24, 2023 | 04:22 PM
  #33
Pako89's Avatar
Can you share a link for the manual where you found the schematics?
Thanks!
Old Jul 24, 2023 | 04:44 PM
  #34
Pako89's Avatar
How did you find out about the 2 valves, Partial and high? do you have a manual where I can see that information?
I just bought an used CLA250, check engine light came off 10 miles after I purchased the car, run the scan and found same code. I am fighting my dealer about this failure, trying to get information together because so far they won't accept my complaint.
Old Sep 4, 2023 | 03:35 PM
  #35
RNadalin29's Avatar
2016 Mercedes Cla 250
This
Is this number 4 hose ?
Old Nov 9, 2024 | 04:03 PM
  #36
wzbhnn's Avatar
2012 ML350 bluetec
Can somebody point out where the line 4 is?
Old Jul 16, 2025 | 11:08 AM
  #37
ZaZo's Avatar
CLA
...so which hose did you flush with Break Cleaner and which one filled with WD40, tia?
Old Aug 21, 2025 | 02:55 PM
  #38
Murf SL's Avatar
2016 C300 2007 SL550
P052E
Originally Posted by CoronaX
Looking for some guidance to resolve P052E(Positive Crankcase Vent Valve Performance) CEL on my CLA250. CEL has been ON and OFF for last month or so. My car has currently 100K on it.
Any schematics, part number or guidance would be much appreciated.
Cheers!
I had the same problem and spoke to the service dept at Oreagan Mercedes and there is an extended warranty on this issue. I have a 2016 C300 and was grateful that the warranty had been extended.
They had the car for most of the day. Even gave me a new C300 to drive while they worked on the car.
Murf
