A Class Satnav disk location?
Old Nov 30, 2013 | 06:34 AM
OZZYAMG's Avatar
03 W211 E55
Hi
Can somebody tell me where I can locate the satnav disk in an A Class 250 sport?
I want to know if I remove it can I use it in my 2003 E55 W211 AMG with satnav.
Regards,
OZZYAMG
Old Dec 28, 2013 | 02:13 AM
iankayem's Avatar
X350d GLE500e 2017, ML350 BlueTec 2012(sold), A200 2013, ML350CDI 2009(sold), Aston Martin DB7 2003
My disk was supplied in the glovebox, same as the other MB's with satnav.
I did ask the dealer if I could plug it into the ML to update the maps. I was advised it will not read in anything other than an A-class, as they come with other coded information. apparently this is a common question from customers with multiple Merc's, and they have tried it before with total failure.
Old Jan 21, 2015 | 01:08 PM
Ghosty's Avatar
C220 CDI Sports Coupe
Hi, above statement is only true to sum extent, if the MB has Becker pre wiring they are totally interchangable, i use my dads from his 2013 (13 reg) c250 in my 2014 (64 reg) a180, both are becker pre wired.
i will however state that this unit can be pin locked to a specfic car i.e. if my dad decides to pin lock it to his i could not use it in mine.
