Instrument cluster backlights turning on and off
Old Mar 14, 2023 | 01:02 PM
Treock's Avatar
A-class
Hello,
My A180d 2017 displayed some issues with instrument cluster backlights.
At the beginning of driving the whole dashboard turns off and on, 2-3 times in a row and then returns to normal.
Went to the official dealership but then couldn't find any errors and just upgraded the software version, but it still keeps happening.
Does anyone have any ideas why this keeps happening? The Battery is relatively new (months old)
Has anyone had such problem ?
Video in the attachment.
Old Mar 16, 2023 | 11:00 PM
W205C43PFL's Avatar
Originally Posted by Treock
Hello,
not sure if the auxiliary battery might also cause this, check that as well.
Old Mar 17, 2023 | 03:10 AM
Treock's Avatar
A-class
Will do, thank you for the suggestion I did change the auxiliary battery about a month or more, before this started happening. Little update - I did notice that sometimes (not every time) when dashboard starts flickering the display on climate control also starts flickering.
Old Mar 18, 2023 | 12:09 AM
W205C43PFL's Avatar
Hmmm, strange and completely no codes? What battery did you replace for both main and auxiliary, is it OEM or compatible battery, if so which is it?
Old Mar 18, 2023 | 05:04 AM
Treock's Avatar
A-class
Just the auxiliary battery, changed it with the same OEM battery that was in there.
I did check the main battery today, and it seems there is a problem with the charging.
So my next step is to check the alternator.
Old Mar 18, 2023 | 09:19 AM
W205C43PFL's Avatar
Good call and good next step.
Old Mar 23, 2023 | 04:05 PM
Treock's Avatar
A-class
Just an update for anyone reading this as it may be helpful to someone.
It was a problem with the alternator not charging the battery enough, and the mechanic that helped me fix this says it's not the first time he seen this problem with this particular model.
Old Mar 23, 2023 | 06:26 PM
W205C43PFL's Avatar
I see, glad to hear it is fixed, curious about how the fix was performed though?
Old Apr 8, 2023 | 07:29 AM
Treock's Avatar
A-class
Sorry for the late reply,
Im not sure on the specific fix, he just restored the alternator that was in the car.
So i didnt need to buy a new one.
Old Apr 9, 2023 | 07:34 PM
W205C43PFL's Avatar
I see glad it worked out that well. Thanks for your reply.
