Interior Fuse Box
I understand I had to remove the foot mats, then the floor carpet, but cant do that properly because there is a plastic piece (panel) covering the sills and going up on the door.
How do I remove that piece? Tried to pull it away from one side (from the bottom) but is still stuck into some hinge or some other restrain system and I dont want to break or rip anything. Can anyone explain how to remove that plastic panel so I can remove the carpet properly?
Thanks!
Thanks!
First time trying to install a dash cam into a Mercedes and I am having trouble with the interior trim panel.
How many panels are suppose to come off to access the fuse box in the 2020 A220. As far as I can tell 2 panels need to be removed. The panel covering the carpet hiding the fuse box and the panel that is covering that panel attached to the dashboard.
Removing the dashboard panel is no problem. It is the panel that covers the fuse box carpet that I simply cannot remove. I can hear the clips pop off from the part of the trim closes to the carpet. But the long part of the trim which runs along side the car. I am unable to pop it off. The side closes to the seat lifts off, but the side of that panel towards the door does not.
Are all the panels held on by clips? I am using the proper tools to pry the trim but I am afraid to use too much force. I have read that it should be clips, but this seems really stuck on for just a “clip”. There was another comment that said to remove the weather sealing in order to remove the panel since it be can be put back, but my weather sealing does not appear to be removable without tearing it apart. It appears to be partly heat shrinked to the metal frame.
I just want to get to the fuse box so I can install my dash cam. If I could just get this panel off properly then everything else would be straight forward.
Just can’t seem to figure it out.
