Aftermarket 19” wheels
Hey guys. I found a set of 19” X 8” wheels that I like. The specs are obviously a bit different from the OEM wheels. They are 1/2” wider and have an offset of 32mm which I think will make the outer lip wider, or stick out about .9” or 23mm as compared to the OEM 19’s.
Do you guys think that would cause problems at all?
I have a 2019 A220 with the AMG line. It currently has the 18” AMG wheels.
Thank you.
Thank you.
No issues at all, but I went with 225/40 tires instead of 235/35. I think that 235/35 tires would be ok, I have seen some A35 with both size, but the OEM Mercedes wheels are 8 inches so I don't know. Seems like there is not enough information yet for this model.
Thanks for the info!!
