Classic Mercedes DIY tips and hints Discussion forum to share your DIY projects.
W111 chassis 1st version transmission linkage issues
Old Jun 11, 2020 | 11:01 PM
GFSHTH's Avatar
1964 Mercedes Benz 220S W111 chassis, 2007 Mercedes Benz C230 Sport
Hello folks ! I hope we are all enjoying the summer. Need help with my transmission: not shifting into 2nd gear. Shifts into 1st, 3rd, and 4th gears. On the column shift lever and 4 speed manual transmission. I have replaced the 2 bushings in the steering column, the bushing in the shift lever on the column, the 2 bushings in the shift rods to the transmission. The shift rods to the transmission are not binding. I want to avoid taking the 1964 Mercedes 220S to the dealer to save costs. Does anyone recommend Your Mechanic.com or someone else to inspect the car in my driveway? I live in the El Cajon, Ca. area in San Diego county.
This one is challenging for me. When I purchased the vehicle, the transmission mount was bent. This could have affected the internal gears ?
Let me know your thoughts and solutions, please. Your friend enjoying all German vehicles, Paul
Old Jun 11, 2020 | 11:07 PM
chassis's Avatar
2017 GLE350 4MATIC
If the transmission mount was bent, the question arises as to why it was bent. In my view this is a candidate for the cause of the 2nd gear issue. The bent mount may cause the transmission to be out of position, creating a shift linkage problem. Something to dig into and figure out.
Old Jun 14, 2020 | 10:30 AM
GFSHTH's Avatar
Transmission issue W111 manual 4 speed column shift
An update: I have replaced the transmission mount which I believe was bent by the front driveshaft coupling blown out.
Yesterday I disconnected the shift rod from the transmission (1st and 2nd transmission levers) and manually put the transmission in neutral ( at the shift lever at column). Then I manually pushed and pulled on the lower shift rod and the rod did move forward and backward. I am assuming now that the 2nd gear does work. Could the problem be the shift rods ? They appear to be the correct dimension. Does it matter which rod I connect to the column shift ball connection ? This transmission has 2 shift levers at the transmission and 2 shift rods at the lower column. Thanks for your help ! I have contacted Your Mechanic. com with no replies yet. Paul
Old Jun 14, 2020 | 04:04 PM
chassis's Avatar
2017 GLE350 4MATIC
Have you seen this?
https://www.benzworld.org/threads/w1...nkage.2644529/
Generally, it's best to assemble the vehicle the way it came out of the factory, re: your question on which part goes where. I notice you started another thread, the pictures you posted seem obvious to me.
Can you reassemble the vehicle in the same way as you disassembled it?
