CarLAB Motorsports - V3 HID System
Old 01-08-2007, 04:22 PM
CarLAB's Avatar
Originally Posted by dannieboiz
I have your V2 and my passenger light is flashing when i drive down the road. It started out as flicker, then a quick flash, no constantly turn off for a few second them back on and then often times it just flashes like the effect of a car bumping their system draining the battery. Check you PM. I need you guys to look @ it.
Come on by tommorow. Its been a while since i installed the HID kit on your car. It might be a bad ballast. It still under warranty so its all good.
Regards
Darwin W
Old 01-08-2007, 06:57 PM
jeannnbeannn's Avatar
2005 clk320 cabriolet
CarLAB...Darwin
How much for install if i buy the HID's through you???
Old 01-08-2007, 07:09 PM
AdamVax's Avatar
05' C230 Kompressor SS Mars Red 6speed--1990 300D 5speed
any pics of the 8000k HID Kit?
Old 01-09-2007, 02:23 AM
oneill_1's Avatar
MB 300E | BMW M Coupe
works even on a W124? any serious mods necessary?
-OG
Old 01-09-2007, 04:35 PM
CarLAB's Avatar
-OG
It will work with your W124.
Regards
Darwin W
Old 01-09-2007, 04:37 PM
CarLAB's Avatar
Install will be free if you purchase the HID from us.
Old 01-10-2007, 12:40 AM
  #32
Darwin---CarLab
Does the HID kit work with both the projection headlights and the reflector headlights?
Old 01-10-2007, 01:54 PM
  #33
CarLAB's Avatar
Yes, they will work for both as long as the bulb type is correct. If you have depo projector lights, they still use H7 type bulb.
Regards
Darwin W
Old 01-10-2007, 07:43 PM
  #34
FlatlineEF9's Avatar
1996 E320, 2018 Ducati Panigale V4S, 2012 1199 Panigale
here is darwins work. 6500k headlamps and fogs.
Old 01-10-2007, 08:20 PM
  #35
Cappa26's Avatar
A box on 4 wheels
Hey Darwin, why do you keep ignoring my pm's?
Old 01-11-2007, 04:17 PM
  #36
Mad TKD's Avatar
hey darwin I just got the kit but have a lot of questions about the install. Can you have someone post specific pics about the install
Where do you plug the 2 metal plugs into that come out of the ballast(red plug and wire)
This is for a 211
david
Old 01-12-2007, 02:19 PM
  #37
Jweiss@carlabms's Avatar
he probably busy, just pm me instead
Old 01-13-2007, 12:02 PM
  #38
305-E55's Avatar
2017 Charger Hellcat
Originally Posted by CarLAB
Migs,
I've been trying to contact you regarding the fogs. Call me at 408 855 8245 when you have time. You might have a bad ballast/igniter.
Regards
Darwin W
Darwin, I recieved the new igniters on thursday and had them installed on friday, so far everything is in working order and they look really nice thanks, Miguel
Old 01-13-2007, 12:27 PM
  #39
Mad TKD's Avatar
I would like to return the kit for refund please. never installed it. Send me the address to return it to.
Old 01-13-2007, 03:36 PM
  #40
raymond g-'s Avatar
99 E320
Regards
Darwin W
that doesn't sound quite right. the bulb needs to reflect characteristics of
a D2R bulb, not an H7, if used in a reflector headlight. but as far as I know,
all the bulbs in your kit are the same...but the bases are different. so can
you clarify? do the bulbs differ if used in a reflector housing vs a projector
housing?....and if so are the bulbs different if used within an HID projector
versus a halogen projector?
side note: Osram and Phillips designs different bulbs for projector vs reflector
because the focal point is different....and because the light housing requires
different source/beam specifications.
Old 02-26-2007, 06:19 PM
  #41
eddie's Avatar
2004 E500 4Matic
Raymond, H1, H3, H4, 9004/5/6 and D2R are designed for reflectors, H7, H11, and D2S are designed for projectors. HID bulbs that have a molded base are designed to be cost effective in any situation.
Old 02-26-2007, 06:54 PM
  #42
yeuchau's Avatar
Stage 2 C7 A6, QX60
do you have like 6000k and 5000k
cause not really interested in anything over 6000k
thanks
Old 02-27-2007, 12:51 AM
  #43
yeuchau's Avatar
Stage 2 C7 A6, QX60
is the 3m double sided tape to mount gonna be strong enough to hold the ballast in engine bay, cause it's hot in there
Old 02-27-2007, 11:27 AM
  #44
Cappa26's Avatar
A box on 4 wheels
Its not, in the long run it'll fall off and go down to the rain guard. Use zip ties.
Old 04-05-2007, 10:08 PM
  #45
kevblah's Avatar
E90 M3
Has the price on these gone down at all?
Old 04-08-2007, 04:41 PM
  #46
CDP
CDP's Avatar
W124's
I'm interested in these for my W124.
Does the kit come with the H4 Headlight/H3 Foglight adapter plug?
6500K would be my choice. TIA!
