AMG SL55 turbine/radial/DTM style wheels/tires
Old Feb 1, 2004 | 12:17 AM
JayCLK430's Avatar
2010 CL63
AMG SL55 turbine/radial/DTM style wheels w/ Yoko 235/40/18 and 265/35/18 tires
$1800 - Like new condition, no scratches/bends or anything. I've only had them for 3 months and they have less than 3,000 miles on them. Tires are Yokohama AVS ES100 235/40/18 and 265/35/18 - perfect for CLK or C class. Wheels are 18x8.5 (ET30) and 18x9.5 (ET33). Located in SF Bay Area - contact me at joong@yahoo.com
Old Feb 5, 2004 | 02:54 PM
JayCLK430's Avatar
2010 CL63
To clarify for people who have emailed me, these are factory AMG wheels, off of a new SL55. I changed the tires from 285/35/18 and 255/40/18 to 265/35/18 and 235/40/18 because I used them on a different car which required lower profile tires. They also have AMG center caps, not Mercedes caps as in the picture. They are flawless.
Old Feb 13, 2004 | 04:37 PM
JayCLK430's Avatar
2010 CL63
Price lowered to $1600
Old Feb 13, 2004 | 11:25 PM
Accomplice8's Avatar
xx
Will these fit a C32 or 2003 E55?
Kevin
Old Feb 14, 2004 | 11:27 AM
JayCLK430's Avatar
2010 CL63
From what I've read in the archives, they should fit perfectly on the E55 but the C32 uses 12X1.5 bolts so they wouldn't work.
Old Feb 14, 2004 | 02:59 PM
KL316's Avatar
03 silver C32 AMG
Re: AMG SL55 turbine/radial/DTM style wheels w/ Yoko 235/40/18 and 265/35/18 tires
sooo.... will they or wont they fit a C32
Old Feb 14, 2004 | 03:24 PM
xx
Any idea how much they weigh?
Old Feb 14, 2004 | 07:34 PM
JayCLK430's Avatar
2010 CL63
Re: Re: AMG SL55 turbine/radial/DTM style wheels w/ Yoko 235/40/18 and 265/35/18 tires
Depends - if the C32 uses 12X1.5 bolts, then the hubs would need to be tapped to accept 14X1.5 bolts. I don't know if there are 14 mm to 12 mm adapters that you can put on the wheels. It might be something you could check into.
Old Feb 14, 2004 | 07:37 PM
JayCLK430's Avatar
2010 CL63
Sorry I don't know but they're not the lightest wheels out there. On the bright side, they're probably strong due to the extra mass :p
Old Apr 14, 2004 | 12:48 AM
JayCLK430's Avatar
2010 CL63
Still for sale. These will fit all W211 E class models. $2300 through Tire Rack!
Old Jun 3, 2004 | 05:41 PM
JayCLK430's Avatar
2010 CL63
$1400 Firm
