CLE Class Coupe (C236) & Cabrio (A236) 2023-
Spacesaver Spare
Old Oct 30, 2024 | 06:07 PM
gsd99mg1's Avatar
w205
Spacesaver Spare
I have a spacesaver spare from a 2020 bmw x1. i’ve checked all specs from that x1 and cle and
they are the same (hub bore, total diameter, bolt pattern) and they are the same, only this weel is 17” and from what i can see the cle only comes with 18 to 20” wheels.
would the 17” fit for emergency use or should i buy a new spare tire? i’m a little nervous to travel through areas with poor cell coverage with just the tirefit kit.
Old Oct 30, 2024 | 09:33 PM
W205C43PFL's Avatar
You could definitely consider a spare tire, but in the case of the bmw x1, I thought they use cone seat lug bolts wheels?
As for options, I wonder something like this will work? It was intended for the W205 C-Class, so check all the offset and stuff first though: https://mbworld.org/forums/c-class-w...are-wheel.html
Old Jul 3, 2025 | 08:56 AM
dudley07726's Avatar
2023 BMW M340i, 2025 MB CLE53 AMG
I'm purchasing this spare for my 25 CLE53 AMG, I've purchased from them once before for my 23 BMW M340i and it fits perfect.
I have no doubt this will as well. While the tire fix repair kit may be fine for certain flats. it's not going to help if there's a hole on the side wall.
https://ez-sparewheel.com/products/2...+AMG+4Matic%29
Old Jul 3, 2025 | 09:59 AM
gsd99mg1's Avatar
w205
thanks, it did fit indeed. i put the wheel on to try it and it worked perfectly.
