Garage Door Opener Problem
Best approach finding the culprit is process of elimination. No, I'm not suggesting to have your wife whacked
. Have her leave her purse etc. in the house or have somebody else ride with you to see if it's the presence of a passenger in the seat triggering an odd bug, or indeed something or someone interfering with the signal. The human body itself also interferes. The Homelink frequency range is right in the sweet spot of where the human body is most efficient at absorbing radio signals. You may have experienced in the past with transistor radios receiving static if you touch the antenna or even got near to it. Potentially a static charge from a piece of clothing could also interfere.
https://cimg7.ibsrv.net/gimg/www.mbw...e010bc060d.jpg
https://cimg8.ibsrv.net/gimg/www.mbw...ff57c698f3.jpg
On another note, I tried opening the garage with the buttons I set on her Q5, with both of us in the car, and it works... Next I'm gonna try a couple scenarios in the Mercedes.
I have the Meross unit. It was an inexpensive (Amazon) simple install and it works flawlessly with my 25 year old garage door opener. 95% of the time I am in my car I use the button on the rearview mirror. My main use case for the Meross is for when I am not in my car and I'm outside and want to open or close the garage door. For example, if I go for a walk or a friend picks me up as it is easier for us to enter the house through the garage door. I just tell my iPhone or Apple Watch, "Hey Siri, open/close the garage door." And it works with CarPlay, too.
HOWEVER...... The problem doesn't appear to be with my garage door opener, it appears to be some sort of weird thing with the car. Because, I went out last night, with the wife in the car, pulled the car out of the garage, wife got in, and it worked, the garage closed. BUT, when I returned home, I pulled into the driveway, where it works every time when it's just me in the car, and IT DID NOT WORK. The button on the rear view mirror didn't work, AND, I brought the actual garage door opener with me, that did not work either. My wife got out of the car and went into the house to open the garage for me and even with her not only not in the car but nowhere near the car, nothing opened the garage except the hard wired button inside the garage. And like I said in my last post, the button in my wifes Q5 works fine with both of us in the Q5...
So what could be happening?
I'm going to play around with this today and see if I can figuere something out, this is really frustrating.
Your observed behavior is definitely strange. Now that you are saying your clicker didn't work, either, I have another thought. When was the last time you put in a fresh battery? I ran into this in the past. If the battery is too weak in the clicker, then it either doesn't program or doesn't program correctly. Repeat everything with a fresh battery.
As far as the remote, it's got a fresh battery, so that's not it.
I'm still having the same issues with the regular garage remote and the car buttons when there's another person in the car, but the Meross app works when another person is in the car because it's triggering the door via wifi and not the radio signal, but again, the HomeKit app seems un-reliable.
https://support.apple.com/en-us/102557
https://support.apple.com/en-us/102287
