CLE Class Coupe (C236) & Cabrio (A236) 2023-
Radar detector rearview mirror powered
Old Nov 6, 2025 | 10:57 AM
WLB's Avatar
WLB
2026 AMG CLE53 2026 Vistiq
I want to install a radar detector left of the rear view mirror as I have done in many of my other vehicles and tap into the wiring behind the windshield mirror/dashcam shroud. I need to know best way to remove the shroud and the best place to tap for 12V.
Thanks in advance for any assistance.
Old Nov 7, 2025 | 08:11 AM
WLB's Avatar
WLB
DISREGARD I FIGURED IT OUT.
Old Dec 11, 2025 | 02:31 PM
BACnMercedes's Avatar
19 E63s, ‘24SQ8, wanting another gas guzzling V8
Let’s see your handy work. I pick mine up tomorrow and will be installing one soon.
Old Dec 11, 2025 | 07:22 PM
WLB's Avatar
WLB
Sent you a PM.
Old Dec 13, 2025 | 04:10 PM
john9999's Avatar
CLE53
Can you also pm me how ( Which wires you tapped for switched 12V) you got power from rear view mirror. Right now I am getting power from cigarette lighter plug under passenger.
Old Dec 14, 2025 | 03:17 PM
Cherk947's Avatar
CLE 53
Careful with pulling power from that area. I heard that the cameras and sensors could have errors with the power draw from some detectors. I just pulled power from the power under the glove box. No issues
Old Dec 15, 2025 | 08:21 PM
dmunozj's Avatar
AMG CLE 53
I ran de usb cable behind panel and through the glove box and plugged to the usb c connector, works perfectly
Old Dec 21, 2025 | 07:04 PM
mgwhiskey's Avatar
2026 CLE 53 AMG Cabriolet
would love to know what wires you tapped into. Thanks!
Old Dec 22, 2025 | 07:44 AM
WLB's Avatar
WLB
After an exhaustive search I was unable to find a switch activated 12 volts and did not want to run a wire from the trunk so I tapped into the dash cam power plug which is easy to get to in front of the rear view mirror. I mounted the detector just to the left of the large black cover (go on line for pictorials on how to remove) The only down side is you have to remove the plug from the detector when not is use as the power is always on. Works for me.
