have to slam doors.....
Also, can you install the piece from the s-class to close the doors softly....I really hate slamming a door shut
As far as the soft-shut doors from an S-class, the striker and latch apear to be the same, but i'm not sure.
I too cleaned and lubricated the seals. Recently though, when you shut the doors, it soundt like a rock hitting the glass. If you push down on the door when you shut it, it works better but you still have to shut it with some force. It's just embarassing when you have a guest in a nice car and their truck doors work better you know?
If anyone knows where I can get these parts besides a stealer, please let me know. Thanks in advance.
i leave the sunroof poped up all the time and the door closes with ease... i think it's cause or air or soemthing getting no where when u close the door so the presure keeps the door from closing shut...
I'm new to this, but thought I might be able to help. My 1998 CLK320 had the same problem with the windows rolling up too high. When the door was shut, it would catch on the rubber strip at the top, and leave a gap down the side of the window. I phoned the stealer, and they advised that an adjustment would be about £120! What I found out is that if you open the door, roll down the window to the bottom, and then lie down underneath the door you will see some rubber plugs. Take these out, and then look up inside these holes, and you will see some star shaped bolts. These are the stops for the window regulator, and are adjustable. You will need a female Torx socket of the appropriate size. To make the window stop a little lower, turn the two adjusters (front and rear of window) a quarter of a turn clockwise each (or more as required), and then check the alignment. Ajust them up or down as appropriate, and check the alignment by winding up the window and shutting the door. Don't forget those seals do need to keep the weather out! When you have got the adjustment right, replace the rubber plugs, and then sit in the car, and wind the windows up by holding the switch at the first position (not one touch up), then hold in the 1st position for about 5 seconds. They should then function correctly, and you shouldn't have to slam the doors!!! It worked on mine!
Hope this helps.
Pete
