Help removing Door Panel
Old Mar 23, 2005 | 02:51 PM
slowsupraTT's Avatar
99 clk430
Ive tried taking it off but i must be missing something. I took out all the screws and everything but something seems to be holding it near where the door adjustment thingie is. Thanks for your help.
Old Mar 23, 2005 | 03:59 PM
BklynBenz's Avatar
CL500
i remember when i took the door panels off my old w202 to install the w210 blinking mirrors and run the wires there was a screw behind the SRS plastic badge, a few more under the door pull and some along the edge of the door. did you get all the screws? also once i got all the screws out, the door panel was still on there good with all these plastic tension clips, i broke like 5 of them trying to get the door panel off. sorry, i never took my w208 door panel off so i cant comment on that one.
Old Mar 23, 2005 | 05:37 PM
Scottjr2005's Avatar
There is a screw behind the srs plastic cover. Also, remove the door handle plastic covering, it snaps on and off, there is a big screw back in there you need to take out. Hope that helps.
Old Mar 23, 2005 | 05:52 PM
99 clk430
I already have gotten that far. There must be something else that im missing.
Old Mar 23, 2005 | 07:58 PM
midget fidger's Avatar
E550 Coupe
haha my mechanic says these doors are a b*tch to work on because the clips break real easy...so watch out!
