What happend to my car ??????
You can buy them on ebay (v6) for around $100 USD. It is a 10 minute job to fix and you can do it yourself.
So now I have to figure out what the problem with the soft top is. the mechanic said it could be just some sensors that are not working. the roll bar wound'nt work either. using now alldata to locate the top hatch swith which was reportet faulty by the STAR. but second time checked everything was ok, so it can be it. Any other suggestions, nothing else was reportet on the STAR. just a "!" on the UVS that could be the sensor for the soft top.
The roll cage won't come up either.
I remembered once I drain the battery and it did the samething. So I began charing the batteries. Sure enough once the battery was at full charge the top lowered again.
I think there is a higher minimun voltage required for the top to operate. Try charging the battery with a home charger and see if it works. Starting the car and let it run for a bit might also do the trick. But just by starting it is not enough though.
