Paint code
Old Dec 6, 2001 | 09:48 PM
R. Range's Avatar
'10 E63
Paint code
Where is the paint code located on a CLK? I'm thinking about ordering the prepainted body color replacements for the orange reflectors on the sides of the front bumper of my '01 55, and want to make sure I get the right black. Also, I am correct that the stock pieces are just reflectors and don't light up, right (don't want to lose turn signals or something)? Thanks.
Ronnie
Old Dec 6, 2001 | 10:20 PM
linh's Avatar
99' SLK 230 & 01' CLK 430
Wrong!!! They do light up and the color code is on the label by the door. That label also tell you tire rec'psi etc.
Old Dec 6, 2001 | 10:26 PM
linh's Avatar
Oh, by the way. You can not use the car paint to paint that orange reflector because then you can't see the light when turn. There are special aftermarket paint for that.
Old Dec 6, 2001 | 11:06 PM
awiner's Avatar
2003 CL55 AMG
The paint code can be found on the door jamb label as well as some labels under the hood. Once the lenses are painted, you will not have much light (if any at all) that will pass through the reflector.
Some people have used a "Smoke" type paint that is translucent. In this scenario, light will pass through the Smoked lenses.
I have a set from EvoSport and am very pleased with the fit and finish ! EvoSport starts with Mercedes Original Eqip. lenses and finishes them with Factory OE paint. Again, not much light will come through when painted this way, however, it looks very nice.
Old Dec 6, 2001 | 11:07 PM
lee2375's Avatar
W212 E63, Audi R8 4.2, Panamera S, Range Rover Sport GT
i used regular car paint to paint mine, and I don't have any problem.
Old Dec 6, 2001 | 11:34 PM
R. Range's Avatar
'10 E63
Thanks for the info. The EvoSport pieces were what I was looking at, and I think I'll order a set. How do you remove the existing ones anyway?
Ronnie
Old Dec 6, 2001 | 11:45 PM
lee2375's Avatar
use a thin flathead screwdriver, pry out slightly, and press in the two tabs
