Check Engine Light On!!
Old Jun 10, 2005 | 10:40 AM
clk22's Avatar
2003 clk55
The check engine light came on after i went over a pothole. And it has gone on for 24hrs straight and then just shut off. then after driving for a little it came back on. has this happend to any one be fore. i took it to my mechanic and he said its probably just a sensor.
THanks for any help!!
Old Jun 10, 2005 | 12:20 PM
cscordo's Avatar
2001 CLK 320
Damn- your mechanic should've had more info than that.
Any time the Check Engine Light comes on, the mechanic should use an ODBII reader to get the message from the car regarding the issue.
If he didn't check that first, get a new mechanic... or get your hands on an ODBII reader. I got mine for about $100 and now I can see what the issue is my self when the CEL comes on.
Old Jun 11, 2005 | 03:26 PM
2Pac's Avatar
2001 CLK 430 conv. 2007 CLS 63
Damn dude!! The exact same thing happened to me yesterday!!! I hit a pothole and the damnlight came on. I have yet to take it to the dealership cuz i know they will charge $100 just to pop the hood. Keep me posted w/ what happened to your car.
Old Jun 11, 2005 | 04:06 PM
clk22's Avatar
2003 clk55
the lights been off for 24hrs now so... i dunno wat to do??????
Maybe its just because of the excessive heat in MA
Old Jun 11, 2005 | 05:34 PM
2Pac's Avatar
I've reading about how if your gas cap is loose then the light will come on. I check my gas cap and indeed it was loose, but after I retighten it, the light is still on. I drove the car for 5 minutes and nothing so far. I'll check tomorrow and see what happens....
Old Jun 12, 2005 | 02:48 AM
clkal's Avatar
01' CLK55
o2 sensors or MAF..... unless it's your gas cap.
Old Jun 13, 2005 | 09:55 AM
str8ridin's Avatar
05 E55
Autozone, Advance Auto Parts etc. will read your codes for FREE.
Old Jun 13, 2005 | 10:53 AM
drli's Avatar
CLK430
Yes, when my light came on it was for both the o2 sensors & MAF. It would turn on/off every few days.
Old Jun 14, 2005 | 05:27 PM
Ironmudd's Avatar
CLK430 designo
You need to drive it for a period of time without the error happening again and then shut it off and then repeat twice. You can't just start and stop it, it has to be driven for awhile. But if the error is still occuring (whatever it was), the light will not shut off by itself.
Old Jun 14, 2005 | 06:26 PM
clk22's Avatar
2003 clk55
I had it diagnosed and its either the MAF or the 02 sensors, HOw much do these cost to replace?
Thanks for the help so far
Old Jun 14, 2005 | 06:37 PM
str8ridin's Avatar
05 E55
Your MAF will set off the O2 sensor codes. Most likely, it's your MAF. They typically go out between 50-70K miles. Search MAF sensor on google and you should be able to get it for $220 or cheaper on ebay. It's a 10 minute do-it-yourself job.
Old Jun 14, 2005 | 10:25 PM
clk22's Avatar
2003 clk55
i only have 38,000 on the clock
Old Jun 15, 2005 | 12:01 AM
drli's Avatar
CLK430
I had less then 50k when mine went. I think it cost about $230.
Old Jun 15, 2005 | 12:32 AM
clk22's Avatar
2003 clk55
if i was looking for the part would it be the air mass meter.
Old Jun 15, 2005 | 09:47 AM
str8ridin's Avatar
05 E55
yes?
Old Jun 15, 2005 | 10:53 AM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
also, if it was your MAF, you'll notice a change in the performance of your car... if you don't really notice a loss of power, then it may just be ur gas cap
Old Jun 15, 2005 | 11:18 AM
clk22's Avatar
2003 clk55
wat if it was the oxygen sensors
Old Jun 15, 2005 | 11:45 AM
str8ridin's Avatar
05 E55
O2 sensors on our cars don't typically go out that early, unless you've been using some cheapo gas. MAF sensors do. If your CEL doesn't go off after the MAF replacement, then keep it handy because it will go out.
Old Jun 15, 2005 | 04:01 PM
2Pac's Avatar
I have driven the car for 4 days now and teh light is still on. 2 days ago i filled it w/ fresh high octane gas and i made sure the gas cap ws ont tight. I remember when i first hit that pothole my low fuel light came on and it was flashing although the tank was half full. When i parked the car i noticed the fuel cap resting on top so i figured that was the problem, but 4 days later and the light still on!!!
what's next...diconnect the battery or wait longer? i dont think is anything else like sensors and crap....i think.
Old Jun 15, 2005 | 04:13 PM
str8ridin's Avatar
05 E55
Originally Posted by str8ridin
Autozone, Advance Auto Parts etc. will read your codes for FREE .
and reset the light
Old Jun 15, 2005 | 05:22 PM
drli's Avatar
CLK430
I was only able to read the codes... I tried to reset the light and erase the codes, but it didnt work on my car.
Old Jun 17, 2005 | 02:55 PM
2Pac's Avatar
Good news fellas. It took a couple of days but the engine light finally went off, back to breathing again!!
Old Sep 12, 2010 | 03:10 PM
rk5rk5rk5's Avatar
Clk320
Smile Maf clk 320
My clk320 was working fine but now it kinda lossing its power a little bit i think you are right bout changing the MAF sensor i'll have it replaced tom...
