Foglight change?
Foglight change?
How hard is it to change out the foglights on a 01 CLK430 with an AMG body kit?
Is it something I should let the dealer do?
Originally Posted by Josh K
It's super easy if you have jackstands or a way of lifting the car.
CLK 320
Originally Posted by Ghostrider
I actually don't besides the jack that the car came with. But once I get it in the air what do I do then?
I think both the 320 and 430 fogs come with those stupid clips though, so it could be a pain. If you have the AMG fogs on the kit then they probably have those screws in place instead, which should be easier.
Definitely search it up... I know there are a ton of answers around.
Originally Posted by viguera
Do a search for fog lamp / fog light and you'll find a lot of good descriptive answers. I had similar questions last year when messing with mine, both from the bottom (removing the plastic piece under) and from the front (removing the bumper).
One word of advice - do NOT get under the car using the factory jack - we don't want you getting crushed. At the very least, find a friend with jackstands and wheel chocks.
2000 CLK 430
I second what Josh said....that jack stand is a POS....used it a while back and the car rolled over ...almost crushing my leg...luckly I was able to grab hold of the rim and jam it in the wheel well before the car crashed down on the ground. OH yeah....almost ripped out my side skirts too....now a few of the clips are off...
CLK 320
Yep, a floor jack and some stands are some of the best investments you'll make if you plan to do any of this type of maintenance on the car. Add a decent torque wrench and a topsider, and you'll only visit the dealership to buy parts...
Now here is the next question, are the bulbs H1's or H3's? I say a couple of posts in the archives that said they were H3's so which one is it?
CLK 320
reading the posts here re: jacks...what about parking your car over a curb? That aught to give you enough room to get under the car sufficiently to change the fog lamp...cheap and easy.
CLK 320
The panel under the car to get to is in the front of the wheel, so you'd have to have your head in the gutter (literally) to be able to get down there. And chances are you could use a jack and stands for your next brake job, or tire rotation, or oil change, etc.
Sure it could work... just like your dentist could use a hammer and a chisel for a root canal, but wouldn't you rather he used the right tools for the job?
Haha...ROFL...that's true...he'd have his head in the gutter just to change that light blub...I can just picture that right now.... good one. Thanks for sharing your thoughts.
CLK 320
You guys are hilarious.
Your thread actually got me off my *** the other day and I ordered Philips Vision Plus bulbs all around from powerbulbs... replaced both fogs, low beams, high beams and corners. Thanks!
Yeah, but did you ever replace the foglights?
CLK 320
Well once again, less than 2 weeks after changing the bulb, one of my fogs is out again.
I changed it myself, being REALLY careful not to touch the bulb... used quality H1s from Phillips, etc. And this is after replacing the whole fog light assembly before when the bulbs kept burning out. I bet if I replace this one (driver's side) the other one will go in a few days.
I'm thinking there's some bad wiring or electrical problem with these things... the car has been doing this for a while now -- and of course the dealership doesn't find anything wrong.
Originally Posted by mtimmy
Check to see if there is any sign of water in the fog light.,.,..!
it is one of the reason that will make your fog light keep on burning.,
CLK-430
Ghostrider,
Where did you get the bulbs from? If I understood you correctly you said they wil be blue for the Fogs? Are they Halogen or HID? Thanks in advance.
Cheers,
Cheers,
Originally Posted by CLK430SuthernMD
Ghostrider,
Cheers,
Cheers,
Originally Posted by jtbeche
I've heard they're barely less "yellow" than regular lights and not worth it at all. Did you actually get these and put them in yet?
Re: H1s
Hey,
Got the lights yesterday and put em in...they match the xenons better than my LED city lights!
Thanks,
Jeff
No problem, let me know when you get them and how they work out.
Mel
__________________
anyone ever seen a brilliant emerald clk? i bet they sold like...10
Quote:
Originally Posted by ricky.agrawal
You're all such ******. I want another post as well. I don't know what's gotten into me. You guys are addicting.. like crack!
