Check engine light still on
Old Aug 22, 2005 | 01:23 PM
clk22's Avatar
2003 clk55
My check engine light has been on for a little while and i took it in today and my mechanic said that there is a leak some were in the intake?? He is searching for it and gonna let me know what the damage is gonna be hopefully not a lot of $$$
Has any one had this problem?
Thanks again
Old Aug 22, 2005 | 09:08 PM
str8ridin's Avatar
05 E55
Thanks again
Take it to autozone or advanced autoparts and have them read the code for you. It's free and will save you a lot of money. When you get the codes, post them here and someone will diagnose it for you.
Old Aug 22, 2005 | 11:58 PM
Bagher's Avatar
1999 CLK430
i bet the code is PO170 or PO171 fuel trim malfunction tis happens to me about once every 2-3 months the airbox is not properly sealed. Bad design.
Old Aug 23, 2005 | 12:26 AM
clk22's Avatar
2003 clk55
Light went off for like 10-20 mins after my mechanic fixed it and then it came back on after i shut off the car for like 10 mins and then started it back up it came on. so should i just play around with the cover until its sealed properly?
THis is annoying and it sux cause my car is out of warranty even though it only has 41k miles.
Old Aug 23, 2005 | 03:04 AM
sicrx65's Avatar
CLK430
My check engine light comes on only when I drive it hard. From startup the light is off, but when I start to floor it or keep it in a low gear using tiptronic it usually comes on, but i'm taking it to the dealer soon.
Old Aug 23, 2005 | 04:51 AM
clkal's Avatar
01' CLK55
it's gonna either be faulty O2 sensors or a faulty mass air flow sensor.
