Installing Wood Steering Wheel?
Old Aug 22, 2005 | 03:18 PM
ITSEL33's Avatar
CLS 55 AMG
Does anyone know how or can explain how to do the install.
Is this a DIY or should I take it to the STEALERSHIP?
Old Aug 22, 2005 | 04:47 PM
Dan Wang's Avatar
E320CDI, CLK55, and a Smart
Its definitely a DIY. There are a couple torx screws in the back to get the airbag off, and one big bolt holding down the wheel. It's recommended you disconnect your battery just in case, but it is not required. Also, do not turn the key if the airbag is disconnected or you risk setting off the SRS light.
Old Aug 22, 2005 | 05:13 PM
lkirchner's Avatar
Several MB's Superperformance MK III Cobra
Remove the torx and then disconnect the air bag connector, then remove the airbag. The large bolt is sometimes a bear to break loose. I have used a breaker bar on the socket and have had someone else hold the wheel so not to jam the ignition lock. All in all pretty easy.
Old Aug 22, 2005 | 05:15 PM
viguera's Avatar
CLK 320
Hmmm... I was thinking about that, but I thought it'd be much more difficult.
What about the steering wheel controls? Do those pop-off too from the old wheel and into the new one, or do I have to worry about some crazy wiring harness to plug those in?
Old Aug 22, 2005 | 07:00 PM
Dan Wang's Avatar
Steering wheel controls are built into the airbag unit.
Old Aug 22, 2005 | 09:42 PM
Scottjr2005's Avatar
where can I get a wood steering wheel for my 98 CLK320? It has the burlwood trim and no steering wheel controls.
Old Aug 22, 2005 | 10:41 PM
ITSEL33's Avatar
CLS 55 AMG
Do I need any special tool to get that big bolt off?
Old Aug 22, 2005 | 10:52 PM
Dan Wang's Avatar
No. Just a socket.
Old Aug 23, 2005 | 04:57 AM
smalldog's Avatar
clk
Give me a call.....I will talk you thru it
Old Aug 23, 2005 | 09:10 AM
viguera's Avatar
CLK 320
I've seen a few on ebay, but I don't know if they're any good... Jerry @ formymercedes carries some too, but he doesn't have prices listed.
Old Aug 23, 2005 | 07:08 PM
ITSEL33's Avatar
CLS 55 AMG
Thanks guys for the help. I originally made an appointment at the stealership
To have it installed, they said it would take 1.5 to 2 hrs. for the install. What
a joke. It took me 15 min. to do it myself. Smalldog(thanks for the help) will post pics soon.
