Has any one used these hid's
Old Aug 28, 2005 | 11:32 PM
clk22's Avatar
2003 clk55
Has any one had any exprience w/the McCulloch 8000k HID Xenon KIT
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Good??? Bad???
Old Aug 28, 2005 | 11:57 PM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
yes... i installed a set of those in my friend's W202, and it worked out great... plug-n-play, with no bulb out error...
My only suggestion is to step it down to at max a 6000K... 8000K won't be very bright and cause a lot of glare...
Old Aug 29, 2005 | 11:02 AM
clk22's Avatar
2003 clk55
will i have to worry about the wiring going???
Old Aug 29, 2005 | 11:33 AM
mmgrad's Avatar
worry about what wiring? everything is plug & play as long as you get the H7 kit... no wire cutting or splicing needed.
the only concern you should take into consideration is where to mount the ballast & igniter... they are both pretty small, so, should be able to fit almost anywhere... but, if not, you'll need to remove the headlight to mount it underneath the light or somewhere on the frame...
Old Aug 29, 2005 | 11:35 AM
ThrillKill's Avatar
CLK/ML
I'm not gonna slam a company but before you buy them do a search on HIDPlanet forum first.
