Lowered with Eibach need help please!!!
02 CLK320 ,bilstein sport shocks, Eiback springs, ECU upgraded, Front grill and emblem, 18" wheels
Hey guys just got my pads from MB. Does anyone know how to tell if they sent me the right ones. Maybe a part number or some other way of telling they sent me #1's
2002 CLK 430/2002 325i
identifying spring pads
you can identify the correct spring pad by counting the nipples on the spring pad...i.e. one nipple corresponds to a #1, 5 nipples corresponds to #5, etc.
00 clk 320 and 3 hondas. Darn I am down to 4 cars.
Hey. I have had Eibach lowering springs for my CLK in a box for weeks, but I am hesitant to install them because I don't want a harsh ride. How do you compare the Eibach springs to the stock ones when it comes to ride quality?
Thanks in advance.
George
Thanks in advance.
George
Hey guys thank you so much for the info. Im thinking about renting a spring compressor and doing it my self without taking everything apart. Has any one done this. Oh well if not ill tell you how it goes.
definately cant rent a regular spring compress you will need the klann plate type mercedes only compressor. The regular one wouldnt fit between the control arm and stuff no room. Thres a procedure somewhere to do it with floor jack and just removing the control arm bolts. I put all my suspension in without having a compressor.
#32
Directions for DIY Spring Pad Removal
#33
lowering spring and Monobloc wheels
Originally Posted by krayzie_e99
so u really think im krayzie?y is that?is cuttin coils not good??i just wasnt satisfied with the huge *** gap and i wanted it to look rite asap.but trust me,my ride runs great.the suspension is really good,not too ruff like i thot it would be.im very hapy with it.
Next, does anyone have the MB factory OEM P/N for the 18x8 and 18x9 inch silver MonoblocII (SL wheel)? They are a five wide spoke OR 5 hole wheel; not a "turbine" look. They are the 88AMG210 sold on Tirerack.
#34
Wallstreet, look at the pix above. I made the mistake on using spring from a coup on a cab. The results are the rear is lower witch turns out that i think it looks cool. The rear of a cab is heavier so that is why the coupe spring are lower. #1 spring pads are recomended in the front to give the vehicle a more even look. The pictures above, show a #3 in front and ill post the #1's installed when i get a chance. Good luck and i hope this helps.
