Headlight replacement?
Old Sep 15, 2005 | 04:50 PM
Ghostrider's Avatar
01 CLK 430
Okay hear's the deal, I have factory HID's on my 01, but I want to upgrade the bulbs to 6000K. My question is how difficult would it be to change the factory bulbs out? Are there any tricks or tips? The dealership wanted $47.50 a piece to change them.
Old Sep 15, 2005 | 06:19 PM
clkgeorge's Avatar
00 clk 320 and 3 hondas. Darn I am down to 4 cars.
$47.50 each is a good deal.
If you can get 6000K from the dealer, installed for $47.50 each You are getting a good deal.
That's labor you are talking about right?
Replacing the bulbs is easy. I would disconnect the + terminal on the battery since the HIDs use very high voltage ballasts.
Old Sep 15, 2005 | 07:17 PM
blackbenzz's Avatar
haters crazy
Its not hard at all to change the bulbs. You just twist the plastic part of fth eback of the headlight off, remove th bulb, change the bulb and reverse the proccess, I can giv eyou more detailed instructions if you want. I have 8k and they are perfect when you first turn them on but then they fade to purple
Old Sep 15, 2005 | 11:27 PM
splib's Avatar
2000 CLK430 Cabrio
If you want 6000K without lower lumens or cheap quality, get Philip Ultinons. About $220 on eBay, and it's an easy install.
Old Sep 16, 2005 | 10:07 AM
Ghostrider's Avatar
01 CLK 430
If you could that would be great. Did you disconnect the battery or use a latex glove?
Old Sep 16, 2005 | 10:08 AM
Ghostrider's Avatar
01 CLK 430
Those are exactly the ones I was going to get.
Old Sep 16, 2005 | 10:09 AM
blackbenzz's Avatar
haters crazy
Yes, I disconnected the battery and wore latex gloves. Just so I make sure I dont miss any steps let me go do it on my car real quick and then post step by step.
Old Sep 16, 2005 | 05:28 PM
Ghostrider's Avatar
01 CLK 430
That would be so awsome, thanks in advance. I'm not that great of a DIYer, but with a little coaching I think I can do it.
Old Sep 16, 2005 | 06:44 PM
blackbenzz's Avatar
haters crazy
I'm feeling lazy so let me see if I can walk you through the proccess from memory instead of going out and doing it.
1) Open hood (everyone should know how to do this)
2) There is a black plastic cover behind the headlight (outer one, and its bigger than the inner one) that twists off to reveal the socket and bulb.
3) Now you take an allen wrench (sp?) (not sure what size) and there are three allens that you need to loosen. They are located around the bulb and hold a brownish yellow plastic piece to secure the bulb in place.
4) Once you loosen all three you should be able to twist the brownish yellow piece counterclockwise and it will click into place, you can now remove the socket w/the bulb.
5) Remove bulb by twisting counterclockwise (I dont remember if you have to push down at the same time, I dont think so though).
6) Put in new bulb and reverse process.
7) Do the same thing for the other side.
8) Send me a check for $100
This is the best I can do for now, if you have any questions feel free to ask.
Old Sep 17, 2005 | 11:21 AM
acb3nz's Avatar
Custom CLK / 05 E500 4matic / 04 Acura TL <<Daily
Good info blackbenzz I need to know this ****.
Old Sep 19, 2005 | 09:39 AM
Ghostrider's Avatar
01 CLK 430
Thanks bb, I will give it a try, but it seems to me number 8 should have been number 1.
Old Sep 19, 2005 | 10:23 AM
blackbenzz's Avatar
haters crazy
