What tyre pressure?
R129 SL320 '99
What tyre pressure?
Guys, now that I have changed to 18" wheels, how do I know what pressure to set in the tyres
Would like help on fully loaded V unloaded.
The car is a CLK430 with 18" Kleemann wheels with 225/40 front and 255/35 rubber on the rear. The tyres are Goodyear Eagle F1's.
I have posted here rather than wheels and tyres due to the specific nature of the set-up on a W208. I am sure our friendly mods will move otherwise
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
32/33 is what's recommended by the factory, and it took my dumb *** over a year (and thousands of $$ in lost wheels) to realize that those numbers aren't appropriate for me. I dented and broke so many wheels on even small potholes with that pressure, so now I've got them at 43/44, with no problems at all. I know people with 20s who have to keep their pressure around 60psi to prevent pothole damage
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
1 Post
2002 CLK 55 AMG Coupe ;)
Re: same subject
Originally posted by 911Jose
What is the recommeded tire pressure for the CLK 55 with the monoblock II wheels and the Michelin Pilot tires? front and back.
thanks
thanks
R129 SL320 '99
Thanks Guys, sounds like this is not as straight forward as I expected especially with real world problems encountered by Newbie and friends.
Newbie, i'll try 38/39 or something in that region and see how I get on. The roads are not very good where I live so I need to consider ride comfort too.
All of them, as much as I can...
I use 43 front and 40 rear on CLK55 cab riding on 19's. Unfortunately, with low profile tires and rims, the opposite applies in that if you ride on rough pothole-ridden roads, gotta UP the pressure! Much rougher ride but you'll save those rims. When I drive into NYC, I use 45/45 PSI.
Also, with a heavy V8 up front and the usual single driver, you'll wear out the sides of the fronts quite faster at the factory-recommended pressures (lower up front) Thread wear on mine with higher front rire pressures are pretty even, although I get a more pronounced understeer in any kind of spirited cornering.
1 Post
Originally posted by Newbie
Just a reminder, these numbers are handily supplied by MB on the sticker inside the gas door.
It recommends 33/33.
That's why my front Michelin Sports wear on the sides: UNDERINFLATED.
To compensate, I am going w/38-40 front and 35 rear after having followed that misleading gas-door sticker for my first virgin 8,000 miles.
Originally posted by karl k
That sticker is confusing and WRONG!
Originally posted by Mark D.
what about for 1/4 mile time....Is it better to have more air in the fronts then in the rears?
I'm sure plenty of people will tell you not to listen to this advice, or that it's dangerous and wrong, but go to the track and you'll see that everyone does it this way.
My best 1/4 mi. times at the track were achieved with the lowest rear tire pressure.
I have 18s and I've gone as low as 12psi in the rear. It was an extreme case, though, because I was drag racing at freezing temperatures up at LACR, the highest altitude and coldest track around (
). I raced a supercharged '00 mustang GT who was running 9lbs in the rear, and kept trying to smuggle a friend into the back seat for more traction, lol. Anyway, this board is hilarous. You guys seem so afraid of damaging your cars
![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
1 Post
I didn't say it was right, wrong, or otherwise. Someone asked what the recommended pressure was, and I told 'em where they could find it. The fact that MB's full of ***** with those numbers is another story.
back to the tire pressure question....
I to was naive enough to leave the tire pressure at the factory recommended setting (those listed on the fuel door), and now, after 10,000 miles, I'm noticing serious camber wear on both the inside and outside (which states that it is underinflated).
So, for a CLK430... what would you suggest I adjust the Psi to be for the front tires? If I adjust the Psi to about 38-40 for the fronts, how much harsher of a ride am I looking at? I do mostly highway/freeway driving in the Los Angeles area (basically like city driving).
The rears look fine, all evenly distributed thread wear, but the fronts are way screwed.
Sorry if this is kinda repetitive (but most responses for this thread were from owners of CLK55s and modified 430s), whereas I am running on the stock rims/tires for now.
Thanks for all/any input!
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
Do you think this would be considered a warranty repair/replacement?
I'm thinking about complaining to the local Benz dealer about this 'Factory Recommended' setting. It is causing excessive tire wear on my fronts (almost more than my rear tires).
Anyone here ever considered having the dealer swap them for new ones?
I don't think it'll fly with the dealer. "Recommended" tire pressures is the opreative word. It would be a tough case to pursue.
Are the OEM 17" AMG Monoblocks (that come with all CLK 430s) considered stock or low profile? I believe the tire depth is 40 series. Thanks, WF!
Originally posted by whiteyford
keep in mind that the sticker is for stock rims and not low pro's. Low pro's almost always require a higher psi
If you keep it at the suggested 32/33 listed on the fuel door panel, this is what you will get:
Under Inflated tire after 10,000 miles
![](http://myweb.thump.net/629819/clk430/24.jpg)
Even tire wear:
![](http://myweb.thump.net/629819/clk430/22.jpg)
![Talking](https://mbworld.org/forums/images/icons/icon10.gif)
The pics really help. I was sure you were referring to the 17" AMGs.
Comparing the even to the uneven is really helpful. So 36 Front and 37 Rears is good?
